Turn on suggestions
Showing results for
02-06-2007 06:06 AM
Hello,
02-06-2007 10:07 PM
Stephen,To wich exactely FabOS Version v5.0.5"letter" will you Update ?
02-06-2007 11:44 PM
OK, I will try upgrading using a telnet session on the other switch in the Test SAN. We will be upgrading to 5.0.5 (no letter). Are there any reasons not to, or to use 5.0.5a/b? Currently only 5.0.5 is supported by one of our storage vendors.Stephen
02-07-2007 12:17 AM
Stephen,Details by v5.2.x can find in the appropriate RN and Comp. Matrix.
