Anonymous
SNMP issue with M5424
[ Edited ]
Hi Everyone,
I'm having a little issue with 2 M5424. (Fabric OS v7.2.1a)
I want to monitored, using SNMP, some things like CPU, Mem, temp sensor, ports...
I'm able to get any information i want about each port... but it seams impossible to get CPU usage, Mem, or any temp sensor.
The only thing i was able to find (snmpwalk-ing ALL the mib), is some kind of experimental OID saying :
SNMPv2-SMI::experimental.94.1.8.1.6.16.0.0.39.248.179.179.4.0.0.0.0.0.0.0.0.1 = STRING: "sensor 1: type 3 is OK, value is 42"
SNMPv2-SMI::experimental.94.1.8.1.6.16.0.0.39.248.179.179.4.0.0.0.0.0.0.0.0.2 = STRING: "sensor 2: type 3 is OK, value is 35"
SNMPv2-SMI::experimental.94.1.8.1.6.16.0.0.39.248.179.179.4.0.0.0.0.0.0.0.0.3 = STRING: "sensor 3: type 3 is OK, value is 39"
(But my Zabbix doesn't like string...)
Edit : i'm having a similar problem with 2 DS300B, i'm able to get Sensor value... but nothing related to CPU or mem
So, Is someone able to help about this ?
Many thanks
