Anonymous
RawBytes OID not showing up in snmpwalk on 7800
We are trying to get to the traffic stats on a 7800 and cannot understand why it seems the following OID isn't returning in the snmpwalk.  Any help appreciated.
xfcipExtendedLinkRawBytes
1.3.6.1.4.1.1588.4.2.1.8
Results from the walk:
]# snmpwalk -v1 -c public x.x.x.x 1.3.6.1.4.1.1588.4|more
SNMPv2-SMI::enterprises.1588.4.1.1.1.1342177536 = INTEGER: 1342177536
SNMPv2-SMI::enterprises.1588.4.1.1.1.1342177552 = INTEGER: 1342177552
SNMPv2-SMI::enterprises.1588.4.1.1.4.1342177536 = Gauge32: 1897
SNMPv2-SMI::enterprises.1588.4.1.1.4.1342177552 = Gauge32: 1896
SNMPv2-SMI::enterprises.1588.4.1.1.5.1342177536 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.1.1.5.1342177552 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.1.1.12.1342177536 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.1.1.12.1342177552 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.54.48.48.0.1 = INTEGER: 1342177536
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.54.48.48.0.7931587 = INTEGER: 1342177
536
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.54.48.48.0.7931784 = INTEGER: 1342177
536
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.54.48.48.0.7931980 = INTEGER: 1342177
536
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.54.48.48.0.7932177 = INTEGER: 1342177
536
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.55.48.48.0.1 = INTEGER: 1342177552
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.55.48.48.0.7935245 = INTEGER: 1342177
552
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.55.48.48.0.7935441 = INTEGER: 1342177
552
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.55.48.48.0.7935638 = INTEGER: 1342177
552
SNMPv2-SMI::enterprises.1588.4.2.1.2.88.48.48.49.55.48.48.0.7935835 = INTEGER: 1342177
552
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.54.48.48.0.1 = Gauge32: 1897
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.54.48.48.0.7931587 = Gauge32: 1897
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.54.48.48.0.7931784 = Gauge32: 1897
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.54.48.48.0.7931980 = Gauge32: 1897
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.54.48.48.0.7932177 = Gauge32: 1897
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.55.48.48.0.1 = Gauge32: 1896
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.55.48.48.0.7935245 = Gauge32: 1896
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.55.48.48.0.7935441 = Gauge32: 1896
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.55.48.48.0.7935638 = Gauge32: 1896
SNMPv2-SMI::enterprises.1588.4.2.1.6.88.48.48.49.55.48.48.0.7935835 = Gauge32: 1896
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.54.48.48.0.1 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.54.48.48.0.7931587 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.54.48.48.0.7931784 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.54.48.48.0.7931980 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.54.48.48.0.7932177 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.55.48.48.0.1 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.55.48.48.0.7935245 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.55.48.48.0.7935441 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.55.48.48.0.7935638 = INTEGER: 0
SNMPv2-SMI::enterprises.1588.4.2.1.7.88.48.48.49.55.48.48.0.7935835 = INTEGER: 0
Anonymous
Re: RawBytes OID not showing up in snmpwalk on 7800
Hi -
it works perfect on mine (running FOS 6.4.3b) :
snmpwalk on OID 1.3.6.1.4.1.1588.4.2.1.8 :
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.48.0.1 = Counter64: 74650872423000
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.48.0.7931549 = Counter64: 74650872423000
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.48.0.7931637 = Counter64: 74650872423000
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.48.0.7931725 = Counter64: 74650872423000
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.48.0.7931813 = Counter64: 74650872423000
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.49.0.1 = Counter64: 74650872423000
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.49.0.7931541 = Counter64: 74650872423000
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.49.0.7931629 = Counter64: 74650872423000
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.49.0.7931717 = Counter64: 74650872609776
SNMPv2-SMI::enterprises.1588.4.2.1.8.88.48.48.49.54.48.49.0.7931805 = Counter64: 74650872609776
Are there any circuit defined on your 7800 ? (portshow fcipcircuit all)
By the way you should consider using standard MIBII ifHCInOctets/ifHCOutOctets OIDs to simply have the whole traffic on Ge ports instead of traffics on defined circuits.
Kind regards,
david
Anonymous
I am not familiar with those OIDs, and unfortunately they do not appear in the snmpwalk either.  The others seem to be there, multicast, broadcast, etc. bit it is strange that they are missing.  The FOS was just upgraded to 7.0.2.
Is there some sort of configuration to enable them?
Anonymous
ifHCInOctets/ifHCOutOctets are parts of If-MIB.
User snmpconfig --show/--enable mibcapability to see of the MIB is loaded or not ... Fabric OS MIB Reference document will provide you more details.
Kind regards,
david
