Anonymous
Process for Migration of switches from Brocade 4100 to Brocade 5300.
Dear All,
I am pretty new to the Brocade Switches. I need to migrate my switches from Brocade 4100 to Brocade 5300. I need to retain all the Zoning configuration on the new 5300 Switch.
Please help me with the process and relevant documentation for the same.
Thanks in Advance.
Regards
Pravesh Upadhyay
External Moderator
Re: Process for Migration of switches from Brocade 4100 to Brocade 5300.
simple way is, made basic config in New Switches, IP and Unique Domain ID.
establish a connection via ISL 4100<-->5300
the entire config will be migrate itself in new switch
TechHelp24
Anonymous
Thanks a lot TechHelp24.
Would also request you if you can help me with the processes for configuration of a ISL between these switches.
Thanks and Regards
Pravesh Upadhyay
External Moderator
You are welcome
TechHelp24
Occasional Contributor
Once the zoning configuration is copied to the new switches - 5300, and all the hosts connections are moved to it, how do you remove the old 4100? what CLI commands do you use to break the ISL, but to retain the config on the new switches?
