New Contributor
Procedure to make a trunk between to san switch in production
I need a procedure to interconnect tow san switch  both with configuration in prodution. I want make a trunk with tow ports.
Broadcom Moderator
Re: Procedure to make a trunk between to san switch in production
Hello Joaquim ,
for a ISL port you need a  trunking licence on each switch .
specifics commands :
portcfgtrunkport command to enable trunking on a port ,  ex for slot 1 port 3 : portcfgtrunkport 1/3 1  ( mode 1 enable )
switchcfgtrunk to enable trunking on all port.
file in attached  with procedures in chapter ' managing trunking connnections' , p 519 .
If this provided you with a solution to this issue,
please mark it with the button at the bottom "Accept as solution"
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided
solely as a convenience for Brocade customers. All systems and all networks are different and unique.
If you have a service affecting network problem, please open a TAC service request for service through
Brocade, or through your OEM equipment provider.
Broadcom Moderator
Hi,
furthermore if I understand you correctly you want to merge 2 existing fabrics into one. To non-disruptive perform this you need to make sure that both zone sets are merged into one and active on both switches PRIOR to connecting them, otherwise the ISLs will segment. You can do that manually or BNA could help you with this.
Secondly of course the Domain IDs need to be unique/different on these two switches.
TL
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided solely as a convenience for Brocade customers. All systems and all networks are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider.
