Contributor
Problem with NTP is not saving my ntp address...
My switch is not saving the ntp address...
Is continue to comeback IPV6 which I do not use IPV6...
tsclockserver 10.10.20.1 after a reboot is change to
BROCADE6510:root> tsclockserver
Active NTP Server               fe80::211:25ff:fec3:724e
Configured NTP Server List  fe80::211:25ff:fec3:724e
Contributor
Re: Problem with NTP is not saving my ntp address...
No one have this problem?
Regular Contributor
check if this explains it:
http://erwinvanlonden.net/2014/03/time-with-and-without-ntp-on-fc-switches/
regards,
Erwin
Kind regards,
Erwin van Londen
Brocade Distinguished Architect
http://www.erwinvanlonden.net The Fibre Channel blog
Q&A -> https://hackhands.com/elo/
