Anonymous
Problem Brocade 5300 and 8gb HBA
I can not get speed 8gb on brocade5300  and qmh2562 hba, port status No_Sync. Only 4gb work
Help
Anonymous
Re: Problem Brocade 5300 and 8gb HBA
I think the cable is the problem. Did you use OM3 cable?
Regards
Michael
Anonymous
Try to change the fill word on the SAN switch. Maybe this helps.
The command is portcfgfillword to change the fill word.
OM3 is only needed if the cable is longer than 50m.
But a good cable quality is good for high speed connections.
I hope this helps.
Andreas
Anonymous
I am sorry, problem in 4 Gb FC I/O c-Class Blade System
Thanks for your help
Regards
Maksim
