Turn on suggestions
Showing results for
05-05-2011 06:08 AM
We are currently experiencing an issue with our DCX whereby one of the power supplies is flashing green. The power supply
was replaced but it is still flashing green. The suspect power supply was moved to another location and it is fine. This has been escalated to brocade, just want to know if anyone else has seen this issue and what was the root cause. Wishing to avoid a complete switch replacement.
