Contributor
Power Cord model for DCX 8510-8 model in stand-alone model to a customer in India ?
I am ordering a DCX 8510-8 model in stand-alone model to a customer in India, but stuck with the options for power cord as I do not have an option to select something specific to the geography India.
Please suggest
Broadcom Moderator
Re: Power Cord model for DCX 8510-8 model in stand-alone model to a customer in India ?
[ Edited ]
Hello,
DCX 8510 is using C19 connectors.
For India there 3 cables availabe with C19 connector on the other end.
They are PCINDIA-EPS, PC15INDIA-BS546 and PC15INDIA-BS1363.
Both first PCINDIA-EPS, PC15INDIA-BS546 are same connector (BS546 is 2,5m and EPS is 1,8m) connectors are round and 16A.
PC15INDIA-BS1363 is more like a UK plug with a fuse inside 13A.
Broadcom Moderator
Attached are the references and drawings of the plugs.
