Anonymous
Out of CAM entries
Hi 2005/12/08-16:39:35, , 1301,, INFO, Julia_02, port 36 enforcement changed to Session Based HARD Zoning.2005/12/08-16:39:35, , 1300,, WARNING, Julia_02, WARNING - port 36 Out of CAM entries
Anonymous
Re: Out of CAM entries
I have attached a technote that will clear this up for you. If you're not using soft zoning then there is nothing to worry about. I have had CAM errors on a 12K for overa year now. No problems at all.
Anonymous
Many thanks for your answer.
Anonymous
I had a huge issue with a HP Taperouter connected to a small switch (cant remember the Brocade type number, its a IBM TotalStorage F16). When i had 80+ servers using tapes thru that router i got scsi errors etc....Unless that port is being used as a tape or other shared device you should be ok.
