Anonymous
Network Advisor (Host Port Mapping won't open)
We recently upgraded from DCFM 10.4.5 to the Network Advisor v11. I have noticed that when I try to access Host Port Mapping nothing opens. The Network Advisor windows becomes inactive and I can no longer access any menu, function etc. The rest of the OS works fine, no impact but the only way I can close Net Adv. is to kill it in task manager (it does show as running). I have tried this using the client on a workstation (XP) on the server (2008 r2) and another server instance (2008).
Any ideas?
External Moderator
Re: Network Advisor (Host Port Mapping won't open)
Similary Issue in VM environmenst was closed as DEFECT in BNA v11.2.0
TechHelp24
Anonymous
Is there a workaround?
External Moderator
Jason,
not sure.
I wrote:
1) Similar Issue
2) in VM environments.
Now is a question, are you in VM Environment ?
TechHelp24
Anonymous
Yes, the NA is hosted on a VM. We do not however manage anything to the VM level, only physical hosts.
External Moderator
Defect ID: DEFECT000341722 Technical Severity: Medium
Summary: Even after renaming or deleting the Host Port Mapping, the changes are reflected only after the next discovery cycle for both VMM and host adapter dialog
Symptom: The user has to wait for the next discovery cycle to get the changes
Workaround: Host discovery will succeed upon next lazy polling since the conflicting host enclosures are deleted.
Feature: VM Support. Function: VM Discovery Setup
Reported In Release: Network Advisor11.1.0. Probability: Low
TechHelp24
Anonymous
I guess that problem isn't what I am experiencing. We cannot even open the Host Port Mapping section of the GUI to attempt changes.
