Anonymous
Max temperatur inside a 6510 switch?
Hi,
I have 6510 switches and  when running a tempshow command,  it shows up with 44-45 Celsius. Is this too high? The switch does not generate any errors.
Regards
gary
Anonymous
Re: Max temperatur inside a 6510 switch?
Operating environment
Temperature: 0°C to 40°C/32°F to 104°F
Humidity: 10% to 85% (non-condensing)
From http://www.brocade.com/products/all/switches/product-details/6510-switch/specifications.page
So outside the switch, temperature up to 40C are ok.
Inside an enclosed and heat producing environment temperatures are always higher then the surroundig cooler air.
With 45 inside I guess outside air (ie in the compute room) is around 25-30 degrees, which is well within limits.
I would not worry about it.
Anonymous
Thanks :smileyhappy:
