Turn on suggestions
Showing results for
07-23-2012 10:13 AM
Hi all.
I have a question regarding my connection between two SAN Switch's currently the 22km distance of separation.
To connect and share the same settings only need the license of "exteded fabric"? or license must also have the "Full Fabric"?
Switch attached licenses.
Switch1:admin> licenseshow
RySQQScQcSzXRRd:
First Ports on Demand license - additional 8 port upgrade license
bSbQbczedScTcRcj:
Extended Fabric license
gLTaZDgY9SABJFLRJRfNWtYHrZNaNmmtBJP9Q:
8 Gig FC license
Switch2:admin> licenseshow
yeQebSbdRzfVfco:
bzRz9yzd99c0S0AF:
GHZ7a4R494HBDYtJrZXRA3ttfD4ZGAARBSKaN:
8 Gig FC license
Thanks for your reply.
greetings.
Felipe Cisternas.
07-23-2012 10:23 AM
Fabric License is mandatory in order to ISL = Inter Switch Link TWO or more switch.
07-25-2012 11:51 AM
might help you.
'Full Fabric' - I believe this is one of HP's Bundles of licenses you can have added to a switch when you buy it.
Perhaps you could find out which licenses this includes?
I believe the link above helps somewhat, but it's not really a definite resource - and perhaps the content differ between the switch models?
After that you could see what the individual licenses provide. You can find the description of each license in the "Fabric OS Administrator's Guide".
Message was edited by: Johan Guldmyr (actually meant to reply to original poster)
07-26-2012 01:34 AM
As far as I know you'll need both. Full Fabric license is the normal Fabric license. I think the name just comes from the old entry model switches where you could have a license that only allow 2 switches in the fabric.
