Anonymous
Login not possible
Hi
I have a Brocade Silkworm 3250 here. When I try to login on the console (connected via the serial-interface) I get the following:
swd77 console login:root
Login incorrect
Who are you?
I tried everything, root, admin,... no luck. I get "Who are you?" right after entering the name (There is no question about the password!).
I have tried to reset the passwords to the default values as described here:
(Boot switch, press ESC within 4 secs, choose "Enter command shell", boot MEM()0xF0000000 -s, mount -o remount,rw,noatime /, mount /dev/hda2 /mnt, /sbin/passwddefault).
Any idea how I can manage to login to that switch?
Thanks!
Andreas
Anonymous
Re: Login not possible
Hi
No one who can help me with that?
Would a FOS-Upgrade help (is a FOS-Upgrade even possible without beeing able to login?). Where could I download the latest FOS-Files?
Andreas
External Moderator
--->>>Would a FOS-Upgrade help (is a FOS-Upgrade even possible without beeing able to login?).
you cannot upgrade FOS without login.
if the reset was successfully, try with default username "admin" and as Password "password"
for root, default password is "fibranne"
TechHelp24
Anonymous
Thanks for your answer. I have allready tried to reset the passwords like described here:
http://community.brocade.com/docs/DOC-1644
But maybe I do something wrong?
This is what I did:
- Boot switch, press ESC, choose "Enter command shell"
- boot MEM()0xF0000000 -s
Linux is booting now
- mount -o remount/rw/noatime /
- mount /dev/hda2 /mnt
- /sbin/passwddefault
  Output: All account passwords have been successfully set to factory default
- reset -f
The switch reboots and starts Linux again.
Now I tried
- passwd root
Output: passwd: User not know to the underlaying authentication module
So I restore the original env and rebooted the switch, FOS is starting.
And now right after entering "root" as username I get the message:
- Login incorrect
  Who are you?
I can´t even enter a password, the system is showing this right after entering ANY username...
External Moderator
Andreas,
procedure as descript in WiKi DOC is correct, however:
--->>> boot MEM()0xF0000000 -s
are you boot from first hda ?
what is printenv output ?
--->>>Output: All account passwords have been successfully set to factory default
- reset -f
is INCORRECT!
correct command is reboot -f and NOT reset
TechHelp24
Anonymous
Hi Antonio,
output pf printenv
AutoLoad=yes
ENET_MAC=00051E34C080
InitTest=MEM()
LoadIdentifiers=Fabric Operating System;Fabric Operating System
OSBooted=MEM()0xF0000000
OSLoadOptions=quiet;quiet
OSLoader=MEM()0xF0000000;MEM()0xF0800000
OSRootPartition=hda1;hda2
SkipWatchdog=yes
You are right, I did enter "reboot -f" and not "reset -f".
I´m not sure about your question about first hda. I have nearly no knowledge about FOS and the Brocade-Switches, in the past we just plugged them in and everything worked fine. But now I need to set up some parameters and for that I need to login to the switch...
Andreas
Anonymous
Hi
I have now changed the config:
AutoLoad=yes
InitTest=MEM()
OSBooted=MEM()0xF0800000
OSLoader=MEM()0xF0800000; MEM()0xF0000000
OSRootPartition=hda2;hda1
SkipWatchdog=yes
And with this configuration the switch comes up fine AND I can login with the default root-credentials!
Thanks for that hint!
Andreas
External Moderator
Andreas,
fine that work.
please mark the thread as "Answered"
TechHelp24
