Contributor
Locate a ICL blade in a DSC
Hi
We need to re-seat a ICL CORE BLADE   52     CORE8  in a DCX
I wonder if there is a comnmand we can use to loacte the blade in the chassis so its easier to find, and so we dont pull the wrong blade ?
Former Brocadian
Re: Locate a ICL blade in a DSC
Hi,
The slots are identified 1 to 12 from the left to the right while looking at the port side of the chassis.
the core blades are located in slots 5 and 8
:root> slotshow
Slot   Blade Type     ID    Status
  1     SW BLADE     51     ENABLED
  2     SW BLADE     51     ENABLED
  3     SW BLADE     51     ENABLED
  4     SW BLADE     55     ENABLED
  5     CORE BLADE   52     ENABLED
  6     CP BLADE     50     ENABLED
  7     CP BLADE     50     ENABLED
  8     CORE BLADE   52     ENABLED
  9     UNKNOWN             VACANT
 10     SW BLADE     51     ENABLED
 11     SW BLADE     51     ENABLED
 12     SW BLADE     51     ENABLED
Kind regards
Rick
Kind regards,
Rick
If my response has solved your query please click the "Accept as Solution" button.
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided solely as a convenience for Brocade customers.
All systems and all networks are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider. .
Valued Contributor
Or, if you have a so called "4 slot" chassis, then you have two port blades, then core, CP, one more CP, one more core and again two port blades.
You can use "portbeacon" command to flash a number of ports on the blade you need to highlight.
