Regular Visitor
LDAP Authentication For FC Switches
Hi All,
Could someone please let me know, for LDAP Authentication for the FC switches to work , if we
-must install  CA on the LDAP servers, for LDAP Autherntication on the switches to work ?
-and, any changes on the Active Directory Schema needs to be updated as well?
The reason I ask this is  that, we have done all the basic configurations on the switches and the role mapping. Still we could not get the LDAP authentication working.
Thanks in advance..
Occasional Contributor
Re: LDAP Authentication For FC Switches
Hi
I had the same issue. You just need to enable LDAPS on you AD (It'll be enabled when you install a cert on the DC/AD), no need to change the scheme.
My original post: https://community.brocade.com/t5/Fibre-Channel-SAN/SAN-switch-ldap-authentication-doesn-t-work-against-Active/m-p/93951#M26589
