Regular Visitor
Issues with DCX8510 CP blade's secondary partition reported after upgrade from 8.1.0 to 8.1.1
Just now seeing error on console. any workaround?
It seems partition on CF card is having issue.
rsync: read errors mapping "/tftpboot/SWBD88/kernel-debug-2.6.14.2-3282828861.ppc.rpm": Input/output error (5)
dcx85108-fcs01:FID128:admin> rsync: read errors mapping "/boot/bootrom.bin": Input/output error (5)
rsync: read errors mapping "/fabos/modules/pluto-zentron-module.ko": Input/output error (5)
ERROR: boot/bootrom.bin failed verification -- update discarded.
ERROR: fabos/modules/pluto-zentron-module.ko failed verification -- update discarded.
ERROR: tftpboot/SWBD88/kernel-debug-2.6.14.2-3282828861.ppc.rpm failed verification -- update discarded.
rsync error: some files could not be transferred (code 23) at main.c(977) [sender=2.6.9]
Here’s what it says..
dcx85108-fcs01:FID128:admin> hashow
Local CP (Slot 7, CP1): Standby
Remote CP (Slot 6, CP0): Active
HA enabled, Heartbeat Up, HA State synchronized
dcx85108-fcs01:FID128:admin> firmwareshow
Slot Name       Appl     Primary/Secondary Versions               Status
  6  CP0        FOS      v8.1.1                                   ACTIVE
                         v8.1.1
  7  CP1        FOS      v8.1.1                                   STANDBY *
                         Unknown
*  Local CP
WARNING: Firmwaredownload is in progress.
FAILED again.
It seems trying to recover secondary partition but then its failing.
--- Partition /dev/hda1 is inconsistent.
dcx85108-fcs01:FID128:admin> rsync: read errors mapping "/fabos/modules/pluto-zentron-module.ko": Input/output error (5)
Service instances out of sync
[64]: Mon Oct 16 17:01:55 2017
Slot 7 (CP1, active): The firmware commit operation has started. This may take up to 10 minutes.
[65]: Mon Oct 16 17:06:31 2017
Slot 7 (CP1, standby): Firmware commit operation has started to restore the secondary partition.
[66]: Mon Oct 16 17:06:31 2017
Slot 7 (CP1, standby): The firmware commit operation has started. This may take up to 10 minutes.
dcx85108-fcs01:FID128:admin> Repairing the secondary partition now.
Please wait ...
Local CP (Slot 6, CP0): Standby
Remote CP (Slot 7, CP1): Active
  6  CP0        FOS      v8.1.1                                   STANDBY *
                         v8.1.1
  7  CP1        FOS      v8.1.1                                   ACTIVE
                         Unknown
*  Local CP
dcx85108-fcs01:FID128:admin> exit
logout
Fabric OS (dcx85108-fcs01)
telnet> quit01 console login:
Connection to ts41h41.gdl.englab.netapp.com closed.
bash-3.00$ rconsole dcx85108-fcs01-cp1
dcx85108-fcs01-cp1(=>dcx85108-fcs01-cp1.gdl.englab.netapp.com) - telnet requested to ts41h41.gdl.englab.netapp.com 2044
Trying 10.228.1.68...
Connected to ts41h41.gdl.englab.netapp.com.
Escape character is '^]'.
dcx85108-fcs01 console login: admin
Password:
dcx85108-fcs01:FID128:admin> slotshow
Slot   Blade Type     ID    Status
  1     SW BLADE     96     ENABLED
  2     UNKNOWN             VACANT
  3     SW BLADE    153     ENABLED
  4     UNKNOWN             VACANT
  5     CORE BLADE   98     ENABLED
  6     CP BLADE     50     ENABLED
  7     CP BLADE     50     ENABLED
  8     CORE BLADE   98     ENABLED
  9     UNKNOWN             VACANT
10     SW BLADE     97     ENABLED
11     UNKNOWN             VACANT
12     UNKNOWN             VACANT
dcx85108-fcs01:FID128:admin> reboot
Warning: This command is being run on a control processor (CP)
based system and will cause the active CP to reboot.
This will cause disruption to all traffic in this chassis.
Are you sure you want to reboot the active CP [y/n]?y
2017/10/16-17:03:42, [RAS-1007], 17074, SLOT 7 CHASSIS, INFO, Brocade_DCX, System is about to reload.
Rebooting! Mon Oct 16 17:03:52 EDT 2017
Broadcast message from root (ttyS0) Mon Oct 16 17:03:52 2017...
The system is going down for reboot NOW !!
INIT: Switching to runlevel: 6
INIT: Sending processes the TERM signal
2017/10/16-17:03:55, [FSSM-1003], 17075, SLOT 7 CHASSIS, WARNING, Brocade_DCX, HA State out of sync.
eth0: Link is down at 31696881 jiffies
eth3: Link is down at 31696897 jiffies
bonding: bond0: released all slaves
eth1: Link is down at 31696920 jiffies
eth2: Link is down at 31696928 jiffies
##RSCMON exiting due to signal: 19, pending signals: 0x0, 0x0
##exiting due to signal: 19, pending signals: 0x0, 0x0
Stopping diagnostics
Unmounting all filesystems.
Please stand by while rebooting the system...
reboot_event: Calling bus0 flush
Restarting system.
The system is coming up, please wait...
U-Boot 1.1.3 (Jun  1 2017 - 11:38:13)
CPU:   8548_E, Version: 2.1, (0x80390021)
Core:  E500, Version: 2.2, (0x80210022)
Clock Configuration:
       CPU:1199 MHz, CCB: 399 MHz,
       DDR: 199 MHz, LBC:  49 MHz
L1:    D-cache 32 kB enabled
       I-cache 32 kB enabled
Board: Zentron
CPU Board Revision 255.198 (0xffc6)
    PCI2: disabled
I2C:   ready
DRAM:  initdram: Initializing DDRSDRAM
initdram: Normal boot in progress
dimm_spd_sdram 2001: memsize = 800
initdram: Call ddr_enable_ecc dram size -2147483648
    DDR: 2048 MB
POST RAM test disabled.
Adjusted memory 0x7d000000 2097152000
Now running in RAM - U-Boot at: 74f7d000
trap_init : 0x0
system inventory subsystem initialized
FLASH:  4 MB
L2 cache 512KB: enabled
CPLD: Init complete
ATA interface setup upm 256: ffcff00, ffcfc04, ffffc00, fffffc01
PCI: gd->brcd_flags = 0, PCI init
Skip our host bridge
        00  11  8086  b555  0680  1a
        00  12  8086  b555  0680  1a
        00  13  8086  b555  0680  1a
        00  14  1131  1561  0c03  3b
        00  14  1131  1562  0c03  3b
           CPLD rev: 0xd0
  CPU0 CPLD version: 0xba
In:    serial
Out:   serial
Err:   serial
Net:
ENET2: PHY is not applicable
ENET1: PHY is Broadcom BCM5461S 10/100/1000 BaseT PHY (2060c1)
ENET0: PHY is Broadcom BCM5461S 10/100/1000 BaseT PHY (2060c1)
ENET3: PHY is Broadcom BCM5461S 10/100/1000 BaseT PHY (2060c1)
board_init_r: Adjusted ram 2097152000 0x7d000000 2048000k
Checking system RAM - press any key to stop test
Checking memory address: 00100000
System RAM test using Default POST RAM Test succeeded.
set_bootstatus: BS_LOAD_OS, platform_idx = 2
Hit ESC to stop autoboot:  0
Map file at LBA sector 0x2b8100
do_bootm 171: load_addr 0x02000000 addr 0x00400000
do_bootm 174: ## Booting image at 00400000 load_addr 0x02000000 ...
   Image Name:   Linux-2.6.14.2
   Image Type:   PowerPC Linux Multi-File Image (gzip compressed)
   Data Size:    2675443 Bytes =  2.6 MB
   Load Address: 00000000
   Entry Point:  00000000
   Contents:
   Image 0:  1596767 Bytes =  1.5 MB
   Image 1:  1078663 Bytes =  1 MB
   Uncompressing Multi-File Image ... do_bootm_linux 565: ## Current stack ends at 0x74F5BB38 => set upper limit to 0x00800000
## initrd at 0x00585DAC ... 0x0068D332 (len=1078663=0x107587)
   Loading Ramdisk to 1fef8000, end 1ffff587 ... OK
initrd_start = 1fef8000, initrd_end = 1ffff587
## Transferring control to Linux (at address 00000000) ...
tlbcam_index=11
mpc85xx_setup: Doing Pcie bridge setup
cpld_init: Map PCI RAS device
Installing Linux 2.6 Kernel
Attempting to find a root file system on hda2...
INIT: version 2.78 booting
Bypassing firmware validation.
--- Its content will be restored to be the same as that of /dev/hda2.
--- Please check the version and re-load firmware if necessary after the system boots up.
INIT: Entering runlevel: 3
loading bonding module
Enabling FOS failure detection feature
enable fabos log
Starting Fabric OS Services...
FIPS off, RRD...
Enter trace_initialize
fablog module loaded with mtracer!
sys_chip_init: class 0 max 24 Done
ethsw_ha_enabled = 1
main-cpu in Neptune...
HASM enable auto-reboot
Detected 2 CPs in Chassis
Probe for PCI timeout detect
Password:
Logging into STANDBY CP, not all commands are fully supported !!
unknown(0):FID128:admin> slotshow
rbash: slotshow: command not found
unknown(0):FID128:admin> firmwareshow
                         Unknown
*  Local CP
unknown(0):FID128:admin> Proxy: ip2ipc started (run=1, rc=0), debug=0
Proxy: ipc2ip started (rc=0)
HAM: HAM:ham_open_htbt:Open heartbeat: 3e0006
HAM: HAM:ham_open_htbt:Open heartbeat: 3f0107
Oct 16 17:05:36  Heartbeat to 3e0006 Up!
2017/10/16-17:05:35, [HAM-1004], 17076, SLOT 7 CHASSIS, INFO, Brocade_DCX, Processor rebooted - Reboot.
Exchange HA Sync between CP
OK let me see if I can console access for both.
I have tried hafailover but it seems second partition has problem.
                         v8.1.1
  7  CP1        FOS      v8.1.1                                   ACTIVE *
                         Unknown
*  Local CP
dcx85108-fcs01:FID128:admin> fabricshow
Switch ID   Worldwide Name          Enet IP Addr    FC IP Addr      Name
  2: fffc02 10:00:c4:f5:7c:8c:20:60 10.228.184.171  0.0.0.0         "brcdg610-lfcs02"
  3: fffc03 50:00:53:35:65:98:4f:7e 0.0.0.0         0.0.0.0         "fcr_xd_3_2"
114: fffc72 10:00:00:05:1e:04:55:98 10.228.184.108  0.0.0.0        >"brcd5000-fcs02"
115: fffc73 10:00:00:05:1e:34:7e:9c 10.228.184.109  0.0.0.0         "brcd4100-fcs02"
116: fffc74 10:00:00:05:1e:44:32:00 10.228.184.110  0.0.0.0         "brcddcx-fcs02"
117: fffc75 10:00:00:05:1e:54:0b:44 10.228.184.113  0.0.0.0         "brcdmace-fcs01"
118: fffc76 10:00:00:05:1e:37:ac:30 10.228.184.114  0.0.0.0         "brcd7500-fcs02"
119: fffc77 10:00:00:05:1e:35:26:30 10.228.184.115  0.0.0.0         "brcd200e-fcs02"
120: fffc78 10:00:00:27:f8:62:b0:a0 10.228.184.231  0.0.0.0         "brcd6505-fcs03"
121: fffc79 10:00:00:05:33:56:9c:00 10.228.184.205  0.0.0.0         "dcx85108-fcs01"
122: fffc7a 10:00:00:05:33:56:59:00 10.228.184.208  0.0.0.0         "dcx85104-fcs01"
123: fffc7b 10:00:00:27:f8:3d:c7:f5 10.228.184.249  0.0.0.0         "brcd6520-fcs02"
125: fffc7d 10:00:50:eb:1a:f9:18:4c 10.228.185.167  0.0.0.0         "brcdG620-fcs02"
127: fffc7f 10:00:c4:f5:7c:2d:35:08 10.228.184.214  172.16.0.61     "brcdx6-4-fcs02"
160: fffca0 50:00:53:35:65:90:1e:7f 0.0.0.0         0.0.0.0         "fcr_fd_160"
The Fabric has 15 switches
Restarting system.
Board: Zentron
    PCI2: disabled
I2C:   ready
    DDR: 2048 MB
trap_init : 0x0
FLASH:  4 MB
CPLD: Init complete
           CPLD rev: 0xd0
In:    serial
Out:   serial
Err:   serial
Net:
   Contents:
tlbcam_index=11
enable fabos log
FIPS off, RRD...
Password:
                         Unknown
*  Local CP
bootenv: Could not get requested variable bootargs.
2017/10/16-17:05:57, [FV-1001], 17077, SLOT 7 CHASSIS, INFO, dcx85108-fcs01, Flow Vision daemon initialized.
SNMP Research EMANATE/Lite Agent Version 16.2.0.9
Copyright 1989-2006 SNMP Research, Inc.
All service instances in sync
2017/10/16-17:06:31, [FSSM-1002], 17078, SLOT 7 CHASSIS, INFO, Brocade_DCX, HA State is in sync.
HAM: HAM:ham_notify:Firmware download failed.
2017/10/16-17:06:31, [SULB-1003], 17079, SLOT 7 CHASSIS, INFO, Brocade_DCX, Firmwarecommit has started.
Validating the filesystem ...
unknown(0):FID128:admin> exit
logout
Password:
                         v8.1.1
                         Unknown
*  Local CP
dcx85108-fcs01:FID128:admin> firmwaredownloadstatus
[1]: Fri Jun 16 00:52:22 2017
Slot 6 (CP0, active): Firmware is being downloaded to standby CP. This step may take up to 30 minutes.
[2]: Fri Jun 16 00:59:17 2017
Slot 6 (CP0, active): Firmware has been downloaded successfully to Standby CP.
[3]: Fri Jun 16 00:59:21 2017
Slot 6 (CP0, active): Standby CP is going to reboot with new firmware.
[4]: Fri Jun 16 01:01:22 2017
Slot 6 (CP0, active): Standby CP booted successfully with new firmware.
[5]: Fri Jun 16 01:02:29 2017
Slot 7 (CP1, active): Forced failover succeeded. New Active CP is running new firmware
[6]: Fri Jun 16 01:03:13 2017
Slot 7 (CP1, active): Firmware is being downloaded to standby CP. This step may take up to 30 minutes.
[7]: Fri Jun 16 01:08:03 2017
Slot 7 (CP1, active): Firmware has been downloaded successfully on Standby CP.
[8]: Fri Jun 16 01:08:07 2017
Slot 7 (CP1, active): Standby CP reboots.
[9]: Fri Jun 16 01:10:04 2017
Slot 7 (CP1, active): Standby CP booted successfully with new firmware.
[10]: Fri Jun 16 01:10:04 2017
Slot 7 (CP1, active): Firmware commit operation has started on both active and standby CPs.
[11]: Fri Jun 16 01:10:05 2017
[12]: Fri Jun 16 01:13:53 2017
Slot 7 (CP1, active): The commit operation has completed successfully.
[13]: Fri Jun 16 01:13:53 2017
Slot 7 (CP1, active): Firmware commit operation has completed successfully on active CP.
[14]: Fri Jun 16 01:13:53 2017
Slot 7 (CP1, active): Firmwaredownload command has completed successfully. Use firmwareshow to verify the firmware versions.
[15]: Fri Jun 16 01:15:24 2017
Slot 6 (CP0, standby): The commit operation has completed successfully.
[16]: Wed Jun 21 02:40:48 2017
[17]: Wed Jun 21 02:40:48 2017
[18]: Wed Jun 21 02:50:17 2017
Slot 7 (CP1, standby): Firmware commit failed - Firmwarecommit failed. (0x1a)
[19]: Thu Aug 10 08:52:36 2017
Slot 7 (CP1, active): Firmware commit operation has started to restore the secondary partition.
[20]: Thu Aug 10 08:52:37 2017
[21]: Thu Aug 10 09:57:13 2017
[22]: Thu Aug 10 09:57:14 2017
[23]: Thu Aug 10 10:06:46 2017
[24]: Thu Aug 10 10:58:02 2017
[25]: Thu Aug 10 10:58:03 2017
[26]: Thu Aug 10 12:02:10 2017
[27]: Thu Aug 10 12:02:10 2017
[28]: Thu Aug 10 12:11:35 2017
[29]: Thu Aug 10 13:03:41 2017
[30]: Thu Aug 10 13:03:41 2017
[31]: Thu Aug 10 13:14:19 2017
Slot 7 (CP1, active): Firmware commit failed - Firmwarecommit failed. (0x1a)
[32]: Fri Aug 11 04:18:46 2017
[33]: Fri Aug 11 04:18:47 2017
[34]: Fri Aug 11 04:28:10 2017
[35]: Fri Aug 11 05:19:43 2017
[36]: Fri Aug 11 05:19:45 2017
[37]: Fri Aug 11 05:30:16 2017
[38]: Fri Aug 11 06:24:25 2017
[39]: Fri Aug 11 06:24:25 2017
[40]: Fri Aug 11 06:33:54 2017
[41]: Fri Aug 11 07:24:20 2017
[42]: Fri Aug 11 07:24:21 2017
[43]: Fri Aug 11 07:34:55 2017
[44]: Fri Aug 11 08:29:20 2017
[45]: Fri Aug 11 08:29:21 2017
[46]: Fri Aug 11 08:38:45 2017
[47]: Wed Sep 20 07:57:40 2017
[48]: Wed Sep 20 07:57:40 2017
[49]: Wed Sep 20 08:08:10 2017
[50]: Wed Sep 20 09:28:14 2017
[51]: Wed Sep 20 09:37:23 2017
[52]: Wed Sep 20 16:22:59 2017
Slot 6 (CP0, active): The firmware commit operation has started. This may take up to 10 minutes.
[53]: Wed Sep 20 16:22:59 2017
Slot 6 (CP0, active): Firmware commit failed - No need to commit firmware. (0x41)
[54]: Tue Sep 26 02:34:45 2017
[55]: Tue Sep 26 02:34:45 2017
[56]: Tue Sep 26 02:36:40 2017
[57]: Tue Sep 26 02:36:40 2017
[58]: Mon Oct 16 16:19:14 2017
[59]: Mon Oct 16 16:19:14 2017
[60]: Mon Oct 16 16:48:48 2017
[61]: Mon Oct 16 16:48:49 2017
[62]: Mon Oct 16 16:58:12 2017
[63]: Mon Oct 16 17:01:55 2017
Please wait ...
After reseated and powered on CP blade. Now it’s in the state below and firmware commit is keep failing.
dcx85108-fcs01:FID128:root> firmwareshow
  6  CP0        FOS      v8.1.1                                   ACTIVE *
                         v8.1.1
                         Unknown
*  Local CP
Have you seen this? And any open issues?
I have requested for remove and reinsert to clear out any errors.
Provide any procedure or recovery steps.
we tried the suggested scenario but unable to disable the CP blade. It gives the below error message:
dcx85108-fcs01:FID128:admin> slotpoweroff 7
Not supported on this slot
dcx85108-fcs01:FID128:admin> bladedisable 7
Blade 7 is being disabled...Failed
Check if you typed a SW BLADE (Not CP) number and
it is within the range, executing 'slotshow' command on the switch.
Also, check if switch disabled or slot off or no blade,
or if the blade is running Diagnostics.
                         v8.1.1
                         Unknown
*  Local CP
  2     UNKNOWN             VACANT
  4     UNKNOWN             VACANT
  9     UNKNOWN             VACANT
11     UNKNOWN             VACANT
12     UNKNOWN             VACANT
I also tried doing firmwaresync but it also failed with below:
dcx85108-fcs01:FID128:admin> firmwaresync
This command will copy the firmware on the active CP blade to the
standby CP blade but will require that existing telnet, secure telnet or
SSH sessions to the standby CP blade to be restarted.
This command may take up to 20 minutes.
Do you want to continue (Y/N) [Y]: y
Another firmware operation is running now.
I think to perform any update we will have to stop the ongoing firmware download process.
Can you look at this?
Here are the detail from switch:
dcx85108-fcs01:FID128:root> slotshow
  2     UNKNOWN             VACANT
  4     UNKNOWN             VACANT
  9     UNKNOWN             VACANT
11     UNKNOWN             VACANT
12     UNKNOWN             VACANT
                         v8.1.1
                         Unknown
*  Local CP
dcx85108-fcs01:FID128:root> firmwarecheck
Validating integrity of firmware on root filesystem
Please wait...
..5....T   /fabos/modules/blaster-module.ko
..5....T   /fabos/lib/libtracedb.so.1.0
Firmware integrity check failed.
-Sunil
Broadcom Moderator
Re: Issues with DCX8510 CP blade's secondary partition reported after upgrade from 8.1.0 to 8.1.1
Hi Sunil,
look like firmware partitions on CP0 are corrupt - notice that from the below both read (of 8.1.1.) and writes are failing
during firmwarecommit.  As long as you have  a pending commit / firmware download (as determined by bootenv variables)
you will not be able to proceed.  The slotpoweroff works on core and port blades, but not on CP, BTW.
Notice that firmwarecheck is also reporting errors - original install of 8.1.1 is probably not complete.
Please wait...
I would open a support case for this to determine if the compact flash is really bad (swap out CP) or can be recovered. How full are the partitions, e.g. what does 'df' report as root?
Broadcom Moderator
Well, here's a last ditch try. You can use the firmwarecleaninstall but here's the rub. It is not as clean as the name implies.
First: Your dir WILL reboot. There is no way around it.
Next: Even if you do a configupload and then configdownload with the 'all' switch, it's unlikely that your logical switches will come back up right. You may have to disable VF, then enable it, then reload the config again.
Finally; Although this will clean up the file system, there is no guarantee that you aren't hitting a double bit error, or some other file system defect.
Proceed with caution if you choose to use firmwarecleaninstall.
doc
Any and all information provided by me is for entertainment value and should not be relied upon as a guaranteed solution or warranty of mechantability. All systems and all networks are different and unique. If you have a concern about data loss, or network disconnection, please open a TAC service request for service through Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, Please mark it with the button at the bottom "Accept as solution".
Occasional Contributor
Very old post, but this solution may help others.
 The issue is usually caused by a full compact flash on the CP.
run ‘supportsave -R’ to cleanup the compact flash,
once run,  try ‘firmwarecommit’ again.
I highly recommend running supportsave -R. Before beginning firmware updates to avoid running into this problem
