Anonymous
IBM 2909 F16 not able to connect
Hi all
Anonymous
Re: IBM 2909 F16 not able to connect
It can be the domain on the switches. All switches in a fabric must have a unique domain id.You can change the domain id in web tools. Depending on the version of FOS you are running, it should be on the first screen that pops up after you log in. You'll have to disable the switch before you can change the domain id.
Anonymous
Hi Cheers
Anonymous
incompatible E-ports means that some fabric.ops setting is not consistant between the two switches. Check your configuration and make sure that all the fabric params are the same (other than domain id of course)
Anonymous
Hi AllSumit
Anonymous
Anonymous
How it decided its problem?Tks
