RSC
New Member
I need some help with configuring the fibre Channel switch with failover
I am newbie to the Fibre channel switch configuration, I need some help configuring the Brocade FC switch for failover. This is a brand new configuration. Please see my attached configuration, does it make sense? Did I miss any configuration? Thank you for all the help.
Here is my switch configuration:
FC switch 1:
RSC-FCSwitch1:admin> nsshow
Type Pid    COS     PortName                NodeName                 TTL(sec)
N    010000;      3;50:06:01:62:47:e0:38:17;50:06:01:60:c7:e0:38:17; na
    FC4s: FCP
    PortSymb: [24] "UNITY::::SPA24::FC::::::"
    NodeSymb: [22] "UNITY::::SPA::FC::::::"
    Fabric Port Name: 20:00:00:05:33:a4:20:f8
    Permanent Port Name: 50:06:01:62:47:e0:38:17
    Port Index: 0
    Share Area: No
    Device Shared in Other AD: No
    Redirect: No
    Partial: No
    LSAN: No
N    010100;      3;50:06:01:63:47:e0:38:17;50:06:01:60:c7:e0:38:17; na
    FC4s: FCP
    PortSymb: [24] "UNITY::::SPA25::FC::::::"
    Fabric Port Name: 20:01:00:05:33:a4:20:f8
    Permanent Port Name: 50:06:01:63:47:e0:38:17
    Port Index: 1
    Share Area: No
    Redirect: No
    Partial: No
    LSAN: No
N    010200;      3;21:00:00:24:ff:8b:f1:7a;20:00:00:24:ff:8b:f1:7a; na
    FC4s: FCP
    NodeSymb: [33] "QLE2562 FW:v8.05.00 DVR:v2.1.63.0"
    Fabric Port Name: 20:02:00:05:33:a4:20:f8
    Permanent Port Name: 21:00:00:24:ff:8b:f1:7a
    Port Index: 2
    Share Area: No
    Redirect: No
    Partial: No
    LSAN: No
The Local Name Server has 3 entries }
Issued following command to create the  configuration:
RSC-FCSwitch1:admin> alicreate rsc_emc_Port4_SPA,50:06:01:62:47:e0:38:17
RSC-FCSwitch1:admin> alicreate rsc_emc_Port4_SPB,50:06:01:6A:47:e0:38:17
RSC-FCSwitch1:admin> alicreate rsc_vmhost5_Port1_SPA,21:00:00:24:ff:8b:f1:7a
RSC-FCSwitch1:admin> alicreate rsc_vmhost5_Port1_SPB,21:00:00:24:ff:8b:f1:7b
RSC-FCSwitch1:admin> alicreate rsc_emc_Port5_SPA,50:06:01:63:47:e0:38:17
RSC-FCSwitch1:admin> alicreate rsc_emc_Port5_SPB,50:06:01:6B:47:e0:38:17
RSC-FCSwitch1:admin> alicreate rsc_vmhost5_Port2_SPA,20:00:00:24:ff:8b:f1:7a
RSC-FCSwitch1:admin> alicreate rsc_vmhost5_Port2_SPB,20:00:00:24:ff:8b:f1:7b
RSC-FCSwitch1:admin> zonecreate rsc_emc_Unity_SPA,"rsc_emc_Port4_SPA;rsc_emc_Port5_SPA"
RSC-FCSwitch1:admin> zonecreate rsc_emc_Unity_SPB,"rsc_emc_Port4_SPB;rsc_emc_Port5_SPB"
RSC-FCSwitch1:admin> zonecreate  rsc_vmhost5_SPA,"rsc_vmhost5_Port1_SPA;rsc_vmhost5_Port2_SPA"
RSC-FCSwitch1:admin> zonecreate  rsc_vmhost5_SPB,"rsc_vmhost5_Port1_SPB;rsc_vmhost5_Port2_SPB"
RSC-FCSwitch1:admin> cfgcreate "Revision1_cfg","rsc_emc_Unity_SPA;rsc_emc_Unity_SPB"
RSC-FCSwitch1:admin> cfgadd "Revision1_cfg","rsc_vmhost5_SPA;rsc_vmhost5_SPB"
RSC-FCSwitch1:admin>  cfgenable Revision1_cfg
You are about to enable a new zoning configuration.
This action will replace the old zoning configuration with the
current configuration selected. If the update includes changes
to one or more traffic isolation zones, the update may result in
localized disruption to traffic on ports associated with
the traffic isolation zone changes.
Do you want to enable 'Revision1_cfg' configuration  (yes, y, no, n): [no] yes
zone config "Revision1_cfg" is in effect
Updating flash ...
RSC-FCSwitch1:admin> cfgshow
Defined configuration:
cfg:   Revision1_cfg
                rsc_emc_Unity_SPA; rsc_emc_Unity_SPB; rsc_vmhost5_SPA;
                rsc_vmhost5_SPB
zone:  rsc_emc_Unity_SPA
                rsc_emc_Port4_SPA; rsc_emc_Port5_SPA
zone:  rsc_emc_Unity_SPB
                rsc_emc_Port4_SPB; rsc_emc_Port5_SPB
zone:  rsc_vmhost5_SPA
                rsc_vmhost5_Port1_SPA; rsc_vmhost5_Port2_SPA
zone:  rsc_vmhost5_SPB
                rsc_vmhost5_Port1_SPB; rsc_vmhost5_Port2_SPB
alias: rsc_emc_Port4_SPA
alias: rsc_emc_Port4_SPB
                50:06:01:6a:47:e0:38:17
alias: rsc_emc_Port5_SPA
alias: rsc_emc_Port5_SPB
                50:06:01:6b:47:e0:38:17
alias: rsc_vmhost5_Port1_SPA
alias: rsc_vmhost5_Port1_SPB
alias: rsc_vmhost5_Port2_SPA
alias: rsc_vmhost5_Port2_SPB
Effective configuration:
cfg:   Revision1_cfg
Switch 2 Configuration
RSC-FCSwitch2:admin> nsshow
N    010000;      3;50:06:01:6a:47:e0:38:17;50:06:01:60:c7:e0:38:17; na
    FC4s: FCP
    PortSymb: [24] "UNITY::::SPB24::FC::::::"
    NodeSymb: [22] "UNITY::::SPB::FC::::::"
    Fabric Port Name: 20:00:50:eb:1a:11:13:e1
    Permanent Port Name: 50:06:01:6a:47:e0:38:17
    Port Index: 0
    Share Area: No
    Redirect: No
    Partial: No
    LSAN: No
N    010100;      3;50:06:01:6b:47:e0:38:17;50:06:01:60:c7:e0:38:17; na
    FC4s: FCP
    PortSymb: [24] "UNITY::::SPB25::FC::::::"
    Fabric Port Name: 20:01:50:eb:1a:11:13:e1
    Permanent Port Name: 50:06:01:6b:47:e0:38:17
    Port Index: 1
    Share Area: No
    Redirect: No
    Partial: No
    LSAN: No
N    010200;      3;21:00:00:24:ff:8b:f1:7b;20:00:00:24:ff:8b:f1:7b; na
    FC4s: FCP
    Fabric Port Name: 20:02:50:eb:1a:11:13:e1
    Permanent Port Name: 21:00:00:24:ff:8b:f1:7b
    Port Index: 2
    Share Area: No
    Redirect: No
    Partial: No
    LSAN: No
Issued following command to create the  configuration on Switch2
RSC-FCSwitch2:admin> alicreate rsc_emc_Port4_SPA,50:06:01:62:47:e0:38:17
RSC-FCSwitch2:admin> alicreate rsc_emc_Port4_SPB,50:06:01:6A:47:e0:38:17
RSC-FCSwitch2:admin> alicreate rsc_vmhost5_Port1_SPA,21:00:00:24:ff:8b:f1:7a
RSC-FCSwitch2:admin> alicreate rsc_vmhost5_Port1_SPB,21:00:00:24:ff:8b:f1:7b
RSC-FCSwitch2:admin> alicreate rsc_emc_Port5_SPA,50:06:01:63:47:e0:38:17
RSC-FCSwitch2:admin> alicreate rsc_emc_Port5_SPB,50:06:01:6B:47:e0:38:17
RSC-FCSwitch2:admin> alicreate rsc_vmhost5_Port2_SPA,20:00:00:24:ff:8b:f1:7a
RSC-FCSwitch2:admin> alicreate rsc_vmhost5_Port2_SPB,20:00:00:24:ff:8b:f1:7b
RSC-FCSwitch2:admin> zonecreate rsc_emc_Unity_SPA,"rsc_emc_Port4_SPA;rsc_emc_Port5_SPA"
RSC-FCSwitch2:admin> zonecreate rsc_emc_Unity_SPB,"rsc_emc_Port4_SPB;rsc_emc_Port5_SPB"
RSC-FCSwitch2:admin> zonecreate  rsc_vmhost5_SPA,"rsc_vmhost5_Port1_SPA;rsc_vmhost5_Port2_SPA"
RSC-FCSwitch2:admin> zonecreate  rsc_vmhost5_SPB,"rsc_vmhost5_Port1_SPB;rsc_vmhost5_Port2_SPB"
RSC-FCSwitch2:admin> cfgcreate "Revision1_cfg","rsc_emc_Unity_SPA;rsc_emc_Unity_SPB"
RSC-FCSwitch2:admin> cfgadd "Revision1_cfg","rsc_vmhost5_SPA;rsc_vmhost5_SPB"
RSC-FCSwitch2:admin> cfgenable Revision1_cfg
Updating flash ...
RSC-FCSwitch2:admin> cfgshow
cfg:   Revision1_cfg
                rsc_vmhost5_SPB
cfg:   Revision1_cfg
Broadcom Moderator
Re: I need some help with configuring the fibre Channel switch with failover
Hi,
I will use fabric 1 as an example. I would create the following zone for HBA to storage (one zon for each storage port)
zonecreate "rsc_P4_vmhosts5_SPA","rsc_vmhost5_Port1_SPA;rsc_emc_Port4_SPA"
zonecreate "rsc_P5_vmhosts5_SPA","rsc_vmhost5_Port1_SPA;rsc_emc_Port5_SPA"
I do not know if the two storage ports need to talk to each other, if yes, then you need the followingf zone, too
And then create  the configuration
cfgcreate "Revision2_cfg","rsc_P4_vmhosts5_SPA;rsc_P6_vmhosts5_SPA; rsc_emc_Unity_SPA"
cfgenable "Reivion2_cfg"
cfgsave
I would also add defzone with noaccess
defzone --noaccess
cfgsave
