Turn on suggestions
Showing results for
01-19-2017 08:12 PM
I have a problem with a Logical Fabric in Brocade 6510 with virtual fabric, this LF don't permit execute cfgneable on default switch, because this reboot immediately
Solved! Go to Solution.
01-20-2017 12:09 AM
Hello,
What is the FOS release installed into this switch?
There is a possible relevant defect listed into 7.4.1d release note. Defect #586977.
Attached is the release note.
01-20-2017 08:01 AM
Hi Thierry
thanks for your help, actually the version is even lower than the one you indicate,
Fa_XXX_YYY: FIDNN: admin> firmwareshow
Appl Primary / Secondary Versions
FOS v7.3.0a
V7.3.0a
So should we upgrade the switch to a higher version than FOS 7.4.1d? What would be the recommended version?
01-20-2017 08:07 AM
Hello,
The recommended version is 7.4.1d.
The defect is fixed into that release.
01-20-2017 09:23 AM
ok thks.
