Anonymous
How to perform Firmware upgrade on Brocade 5000 B from 6.1.0c to 6.4.2?
Please anyone can tell what firmware level jumps I need to follow?
Where can I download the firmware versions?
Anonymous
Re: How to perform Firmware upgrade on Brocade 5000 B from 6.1.0c to 6.4.2?
Hi,
From release notes:
6.4.2b (which will tell you it can only be upgraded from 6.3.x)
6.3.2d (which will tell you it can only be upgraded from 6.2.0a or later)
6.2.2f (which will tell you it can only be upgraded from 6.1.0a or later)
if it's a brocade switch and you got a support contract you can find them under Downloads.
Other vendors provide the firmware via their web sites.
