Anonymous
How to check whether my host are logged in or not through Brocade CLI?
Can anybody tell me that How I can check that whether my hosts are logged in to switch or not?(After Zonning has done)
I have no idea about HBA of those hosts, So what is the command which can shows me if the hosts are logged in or not?
I really appretiate for your help...
Anonymous
Re: How to check whether my host are logged in or not through Brocade CLI?
If I got my Host HBAs , then can I check whether my hosts are logged into switch or not?
Anonymous
I think you have got your answer in the other thread.
Still then you can use cmd like nodefind, alishow, nsshow, nscamshow, nsallshow, portshow, portcfgshow,switchshow
for effective zoning, fcping / cfgactvshow
for every cmd usage, pls use help
Pls make the thread correct if you find it.
Anonymous
Hey Hemant,
Thanks for all your help.
I got this result when I use nodefind command on my alias.
> nodefind neo6f007na1
Remote:
    Type Pid    COS     PortName                NodeName
    N    6a2800;    2,3;10:00:00:00:c9:38:8c:f8;20:00:00:00:c9:38:8c:f8;
        FC4s: FCP
        NodeSymb: "Emulex LP9002 FV3.93A0 DV6.11cx2"
        Fabric Port Name: 20:28:00:05:1e:d2:60:00
        Permanent Port Name: 10:00:00:00:c9:38:8c:f8
        Device type: Physical Initiator
        Port Index: 40
        Share Area: No
        Device Shared in Other AD: No
        Redirect: No
    Aliases: neo6f007n1h2 neo6f007na1
Whats this means? my Host named ne06f007n1h2 is logged in or not?
Anonymous
yes, your host named  neo6f007n1h2, whose wwn is 10:00:00:00:c9:38:8c:f8 is logged in and on port no 40, in switch show you can see this wwn as F port.
in nodefind, if it is not there then it will show you no device found. you can do a nodefind
like : nodefind 10:00:00:00:c9:38:8c:f8
all these you can get from comman reference guide.
