Anonymous
How do I ensure port speed settings don't get reset when the switch is cycled?
I am using both Brocade and QLogic switches and need to ensure that the fixed port speed settings are persistent and remain set after the switch power is cycled.  For QLogic, I have to use config save and config activate commands.  I don't see any similar CLI commands for the Brocade switch - the configuration "cfg*" commands all reference zoning, which I am not using.
I use the portcfgspeed command to set the fixed port speed - how do I ensure it is retained on power up?
Anonymous
Re: How do I ensure port speed settings don't get reset when the switch is cycled?
The portcfgspeed setting is persistent across reboots/power cycles. You don't have to do anything else.
