Anonymous
Help interpreting Brocade 300 ISL port errors, and SFP stats
We have two identical Brocade 300 SAN switches ISL'd together on ports 0 and 15 over LongWave 30km SFP transceivers.  Running FOS 7.0.0c
Issuing a "porterrshow" on switch1 lists a very high number of enc_out errors on PORT15.(>500 errors per second)
Issueing the same command on the partner, switch2, shows no errors.
A "portshow 15" command on switch1 indicates that most all errors are of type "Invalid_word".
The same command on switch2 shows no errors.
A "portstatsshow 15" command on switch1 reports a large amount of "er_enc_out" and "er_bad_os" errors.
Additionally, issuing a "sfpshow 15" command on switch 1 shows an Rx Power value of -20 dBm and a Tx Power of 2.2 dBm.
An "sfpshow 15" command on the partner switch2 shows Rx Power value of -11 dBm and a Tx power of 2.2 dBm.
We're at a loss as to what the issue is at this point.  All fiber jumpers have been replaced/cleaned, and our network team has re-routed the ISL connections on different fiber strands and the errors remain.
Can someone help to interpret these output values for the errors as well as provide input on the variation of the Rx/Tx power values between the 2 switches?
Former Brocadian
Re: Help interpreting Brocade 300 ISL port errors, and SFP stats
Hi barrickd.  I have very basic information regarding your request.
For the first, all i can give you is the definition.  "Invalid_word"-- Encoding errors inside of frames
Regarding "er_enc_out" and "er_bad_os", That counter (er_bad_os) is invalid. Ignore it. Also, you frequently see EncOut (Encoding Error Outside of frame) errors when there are BadOS errors. You can ignore the EncOut errors when there are BadOS errors as well; however, EncOut errors when there are no BadOS errors are geniuine and should be debugged.
But for more information, you would need to contact support.
Regards,
Mike Eversole
Brocade Community Manager
Valued Contributor
Hi,
Every Fibre Channel connection (an ISL in this case) is made up of two separated fibers (one for Tx and the other one for Rx).
We can see the following from your post:
  • Since there are 0 errors in port 0 of switch2, this means that the physical layer is OK from port 15 Tx to port0 Rx.
  • Since there are errors reported in port 15 of switch1, this means that there is possible physical issue in this connection (from port 0 Tx to port 15 Rx)
  • Also the Tx power in both ends is 2.2dBm which in mW is 1.66 aprox. But the Power received in the remote end is very different from a port to the other one:
  • switch1 Port15 Rx power is -20dBm whilst switch2 port0 is -11dBm. This fact shows that there must be something wrong in the connection. moreover, a Rx power of -20dBm is very low and can cause the errors you see in the port.
Please, review again your infrastructure since there is an element that is attenuating the signal by 9dBm.
Kind regards,
Felipon
