New Contributor
Firmware flashing with USB
Hi All,
Our company is doing a lot of storage array installations and im wondering if I could create a USB drive myself to upgrade de FC 6505 switches for example..
or is this a special created USB stick that I have to aquire from brocade self ?
anyone worked with this before ?
thanks
Bauke
Occasional Contributor
Re: Firmware flashing with USB
Only Brocade Branded USB devices are supported
you can try mount with cmd,
> usbstorage -e
non-Brocade branded device will give error something fail to enable
Regards
Sushanth
