Contributor
FOS will not load / fabos not yet initialized: -1
Hi
Brocade 16Gb/28 SAN Switch for BladeSystem c-Class
Switch will not boot up Fabric OS
Error:  fabos not yet initialized: -1
No CLI commands works
Always get errors below
fabsys device open: No such device or address
Also tried a cleaninstaløl of the FOS, no luck
Any tip ?
Broadcom Moderator
Re: FOS will not load / fabos not yet initialized: -1
Hello,
From the short logs you have provided it is looking like to be an issue with the primary partition.
The best is to contact your OEM for try to proceed to recovery by executing a boot to the second partition and then to do a firmwaredownload to recover/repair original partition.
