New Contributor
FOS upgrade on multiple switches on same time
Does anyone done FOS upgrade on multiple switches at same time? Either by using script or some other method(s)?
External Moderator
Re: FOS upgrade on multiple switches on same time
@bali
->.......by using script or some other method(s)?
I do think this is a good idea, excepted they want to get a Fabric Crash.
joking aside......, you should upgrade the switch one at a time, and if you have Dual Fabric, you should perform upgrade first at one Fabric and then in a second Fabric.
TechHelp24
Regular Contributor
Hi,
if you want to upgrade all switches in one Fabric simultanesly you can use the BNA.
Kind Regards
Ralf
