New Contributor
FCIP-7800 switch is not Pushing Data-When WAN changes are made by NW team.Tunnel is UP
We have Brocade FCIP-7800 Switches , Actively Running, Now Network Team is Restricting WAN Traffic One to one , Previously it was Open to All departments Network. When they make changes on WAN, The FCIP switches is not pushing data, Even though Ping and Traceroute is as expected.Tunnels are UP and Running.
1. VE Port disable and enable ( Didnot work)
2.Reboot of switches One after Other (didnot work)
3. TUnnels are Up and running in both above cases, But FCIP switch is not pushing Data.
Occasional Contributor
Re: FCIP-7800 switch is not Pushing Data-When WAN changes are made by NW team.Tunnel is UP
Hello Boina Kumar,
The network team may of allowed the routers to go into a default configuration when the new routes were added.  The default configuration will turn on the Urgent bit.  Please have the network team check to see if the Urgent bit is set.
Regards
Extension_Guy
Peter O'Brien
New Contributor
Hi Peter,
NW team is Changing the VRF Zones, from VRF-Default to VRF- Replication, That is they are Making Replication to talk only for restricted subnets. When I asked them to check about Urgent Bit, Thay have No Clue, Can you elaborate what is significance and Imapat of Urgent Bit and where this can be seen and corrected. Please Help.
Hello Boina Kumar
Here is the explaintion of URG flag setting.
http://www.brocade.com/content/html/en/administration-guide/fos-740-extensionguide/GUID-64E2AF2B-D1D2-4A56-959D-97D68E427239.html
What is your current impact?
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided solely as a convenience for Brocade customers.
Your system and network are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider.
Regards
Extension_Guy
Peter O'Brien
