Contributor
FC8-48 Installation Problem to Director 48000
Dear All,
I’m encountering an issue when installing blade FC8-48 at slot 3 at Director 48000. There are total of 2x FC4-48 (slot 1 & slot 2), 1x FR4-18i (Slot 4), 1x FC4-32 (Slot 7), 2x FC8-32 (Slot 8 & Slot 10). And also the 48000 is installed with 4x power supply and firmlevel at v6.3.1b (both CP)
After I plug in the FC8-48 at slot 3, I check the errdump that the HA became out of sync, & the Active CP (CP1) was failing over to Standby CP (CP0).
below is the errdump capture
2011/08/16-11:10:04, , 2090, SLOT 5 | CHASSIS, WARNING, SilkWorm48000, HA State out of sync.
2011/08/16-11:20:29, , 2091, SLOT 5 | FID 128, INFO, lbg3_B_c01_100, Login information: Login successful via TELNET/SSH/RSH. IP Addr: 10.64.11.134
2011/08/16-11:22:32, , 2092, SLOT 5 | CHASSIS, WARNING, SilkWorm48000, S2,P274(36): at next port state change, best effort QOS will be turned off automatically due to best effort is no longer supporte
2011/08/16-11:22:32, , 2093, SLOT 5 | FID 128, INFO, lbg3_B_c01_100, iSNS Client Service is disabled.
2011/08/16-11:22:37, , 2094, SLOT 5 | CHASSIS, INFO, SilkWorm48000, Connection established between CP and blade in slot 4.
2011/08/16-11:22:45, , 2095, SLOT 5 | CHASSIS, ERROR, SilkWorm48000, CP in Slot 6 set to faulty because CP ERROR asserted.
2011/08/16-11:22:48, , 2096, SLOT 5 | CHASSIS, INFO, SilkWorm48000, Slot 3 Initializing...
2011/08/16-11:22:49, , 2097, SLOT 5 | CHASSIS, INFO, SilkWorm48000, Slot 3 Initialization completed.
2011/08/16-11:23:21, , 2098, SLOT 5 | FID 128, INFO, lbg3_B_c01_100, Four power supplies are now required for 2X redundancy, Switch Status Policy values changed.
2011/08/16-11:23:21, , 2099, SLOT 5 | FID 128, WARNING, lbg3_B_c01_100, Switch status changed from HEALTHY to MARGINAL.
2011/08/16-11:23:21, , 2100, SLOT 5 | FID 128, WARNING, lbg3_B_c01_100, Switch status change contributing factor CP: CP non-redundant (Slot6/CP1) faulty.
2011/08/16-11:24:32, , 2101, SLOT 5 | CHASSIS, INFO, SilkWorm48000, Resetting standby CP (double reset may occur)
2011/08/16-11:24:35, , 2102, SLOT 5 | CHASSIS, INFO, SilkWorm48000, CP in slot 6 not faulty, CP ERROR deasserted.
2011/08/16-11:25:33, , 2103, SLOT 5 | CHASSIS, WARNING, SilkWorm48000, Trace dump available (Slot 6)! (reason: PANIC)
2011/08/16-11:25:33, , 2104, SLOT 5 | CHASSIS, WARNING, SilkWorm48000, Trace dump (Slot 6) was not transferred because trace auto-FTP disabled.
2011/08/16-11:25:33, , 2105, SLOT 6 | CHASSIS, INFO, SilkWorm48000, Processor rebooted - Software Fault:Kernel Panic
2011/08/16-11:25:33, , 2106, SLOT 6 | CHASSIS, WARNING, SilkWorm48000, Trace dump available (Slot 6)! (reason: PANIC)
2011/08/16-11:25:33, , 2107, SLOT 6 | CHASSIS, WARNING, SilkWorm48000, Trace dump (Slot 6) was not transferred because trace auto-FTP disabled.
2011/08/16-11:26:19, , 2108, SLOT 5 | CHASSIS, INFO, SilkWorm48000, HA State is in sync.
2011/08/16-11:26:19, , 2109, SLOT 6 | CHASSIS, INFO, SilkWorm48000, HA State is in sync.
2011/08/16-11:26:20, , 2110, SLOT 5 | FID 128, INFO, lbg3_B_c01_100, Switch status changed from MARGINAL to HEALTHY.
thanks a lot for the help
