New Contributor
E-port invalid flow control mode in ELP
Hi,
   Brocade5000 (port0) after upgrade firmware to 6.1.1d, it failed to ISL with Brocade7500 (port 2)F/W 5.2.1b
switchType:46.2
switchState:Online
switchMode:Native
switchRole:Subordinate
switchDomain:149
switchId:fffc95
switchWwn:10:00:00:05:1e:38:58:f1
zoning:OFF
switchBeacon:OFF
FC Router:ON
FC Router BB Fabric ID:1
Area Port Media Speed State Proto
0 0 id 2G Online LD E-Port 10:00:00:05:1e:38:32:df "FT_7500_A_2" (upstream)
1 1 id N4 No_Light Disabled (Persistent)
2 2 id N4 No_Sync Disabled (Invalid flow contol mode received
In errDump
2010/03/08-02:45:58, , 519,, WARNING, C_7500_A_1, Port 2 was disabled, invalid flow control mode in ELP.
portcfgexport 2
Port 2 info
Admin: enabled
State: NOT OK
Pid format: Not Applicable
Operate mode: Brocade Native
Edge Fabric ID: 21
Preferred Domain ID: 160
Front WWN: 50:00:51:e3:85:8f:1e:15
Fabric Parameters:Auto Negotiate
R_A_TOV: Not Applicable
E_D_TOV: Not Applicable
Authentication Type: None
DH Group: N/A
Hash Algorithm: N/A
Edge fabric's primary wwn: N/A
Edge fabric's version stamp: N/A
fabric.domain:149
fabric.ididmode:0
fabric.ops.BBCredit:16
fabric.ops.E_D_TOV:2000
fabric.ops.R_A_TOV:10000
fabric.ops.bladeFault_on_hwErrlevel:0
fabric.ops.dataFieldSize:2112
fabric.ops.max_hops:7
fabric.ops.mode.fcpProbeDisable:0
fabric.ops.mode.isolate:0
fabric.ops.mode.longDistance:0
fabric.ops.mode.noClassF:0
fabric.ops.mode.pidFormat:1
fabric.ops.mode.tachyonCompat:0
fabric.ops.mode.unicastOnly:0
fabric.ops.mode.useCsCtl:0
fabric.ops.vc.class.2:2
fabric.ops.vc.class.3:3
fabric.ops.vc.config:0xc0
fabric.ops.vc.linkCtrl:0
fabric.ops.vc.multicast:7
fabric.ops.wan_tov:0
fabric.principalSwSelMode:0
portcfgshow:
Ports of Slot 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Speed 2G AN AN AN AN AN AN AN AN AN AN AN AN AN AN AN
Trunk Port ON ON ON ON ON ON ON ON ON ON ON ON ON ON ON ON
Long Distance LD .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
VC Link Init ON .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
Locked L_Port .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
Locked G_Port .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
Disabled E_Port .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
ISL R_RDY Mode .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
RSCN Suppressed .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
Persistent Disable.. ON .. .. .. .. .. .. ON ON ON .. ON ON ON ON
NPIV capability ON ON ON ON ON ON ON ON ON ON ON ON ON ON ON ON
EX Port .. .. ON ON ON ON ON ON ON ON ON ON ON ON ON ON
Mirror Port .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
In Brocade5000
switchType:58.1
switchState:Online
switchMode:Native
switchDomain:121
switchId:fffc79
switchWwn:10:00:00:05:1e:90:09:f6
zoning:ON (Domain5000_C121)
switchBeacon:OFF
configShow
fabric.domain:121
fabric.ididmode:0
portcfgshow:
Speed AN AN AN AN AN AN AN AN AN AN AN AN AN AN AN AN
AL_PA Offset 13 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
Long Distance .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
VC Link Init .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
Persistent Disable.. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
QOS E_Port ON ON ON ON ON ON ON ON ON ON ON ON ON ON ON ON
Port Auto Disable .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
     Do any one know what cause the ISL failed, as another Brocade5000 did not have this issue.
Anonymous
Re: E-port invalid flow control mode in ELP
Try matching the speed, although I have just had a quick look. The flow control seems fine and its the speed and QOS which I think is causing this.
Also the long distance mode is different. set it to same.
portcfgspeed - turn this to auto neg on
portcfglongdistance - change mode to LD
portcfgqosdisable if reqd. I hate QOS.
