Anonymous
Domain id and zone info are missing
Hi experts,
  I am new here. I found GUI of brocade SAN switch is weird.
1. Zone info will disappear(become empty) after a couple minutes.(see screenshot 1, the info is correct at beginning.)
2. Several error messages in main page: duplicated zones, domain id is incorrect when press performance monitor, SWITCH1 becomes red.
3. However, cfgshow(comamnd line) info is correct.
   We don't change configuration recently. HP suggests me to save configuration on swicth 1, remove trunking cables and disable and clear cfg on
   switch 3. After reconnecting to switch 1, the configuration will be repaired automatically. Any comments?
View Fabric Summary from Switch QCISAPSW1:
There are total of 2 domains in the fabric
Local Domain ID: 1  (Switch Name:  QCISAPSW1)
Domain ID:  3  (Switch Name:  QCISAPSW3)
Active Paths:
Destination Domain ID:3  (Switch Name: QCISAPSW3)
Destination's World Wide Name: 10:00:00:05:1e:90:19:26
Number of Path(s) to Domain 1:  1
Metric to reach the domain: 500
Path Number 1:
Output PortInput PortsTotal BandwidthBandwidth DemandHop CountFlag
310 , 1 , 4 , 5 , 8 , 9 , 10 , 11 , 13 , 14 , 15 , 16 , 18 , 21 , 22 , 23 , 24 , 25 , 26 , 27 , 28 , 29 , 304.000 Gbps1950 %1D
Anonymous
Re: Domain id and zone info are missing
What was the trigger that started this?
Anonymous
Hi Dion,
  I don't know. I do not monitor SAN switch frequently. The last time I logged in is probably half year ago. Anyway, I find everything is ok is CLI. so I work in CLI now.
Anonymous
Nevertheless you should resolve the duplicate zones issues.
The webGUI issues may be resolved by clearing java caches.
Anonymous
Hi dion,
The problem is I don't know what's wrong there. It seems that Brocade SAN switches work normally like before. Could you check out my configuration files.
--- SW1 --
boot.name:QCISAPSW1
boot.ipa:.251
boot.licid:10:00:00:05:1e:90:19:4c
boot.mac:10:00:00:05:1e:90:19:4c
boot.device:eth0
boot.gateway.ipa:.253
461A95E2494BD78D646B36B50D1D35E4461A95E2494BD78D3D3B58E6138D2CA88B07
RQzQeQyebRgR0RfB
cQcczydS9zdhhd04
acl.clear:0
ag.port.nfportfailback:0x0
ag.port.nfportfailover:0x0
ag.port.nfporttopo.0:0x0
ag.port.nfporttopo.1:0x0
ag.port.nfporttopo.10:0x0
ag.port.nfporttopo.11:0x0
ag.port.nfporttopo.12:0x0
ag.port.nfporttopo.13:0x0
ag.port.nfporttopo.14:0x0
ag.port.nfporttopo.15:0x0
ag.port.nfporttopo.16:0x0
ag.port.nfporttopo.17:0x0
ag.port.nfporttopo.18:0x0
ag.port.nfporttopo.19:0x0
ag.port.nfporttopo.2:0x0
ag.port.nfporttopo.20:0x0
ag.port.nfporttopo.21:0x0
ag.port.nfporttopo.22:0x0
ag.port.nfporttopo.23:0x0
ag.port.nfporttopo.3:0x0
ag.port.nfporttopo.4:0x0
ag.port.nfporttopo.5:0x0
ag.port.nfporttopo.6:0x0
ag.port.nfporttopo.7:0x0
ag.port.nfporttopo.8:0x0
ag.port.nfporttopo.9:0x0
alpaList:1
audit.cfg.class:1,2,3,4,5,
auth.policy:0
auth.policy.dev:3
cer.internal_port_code:1
cfgload.secure:0
cfgload.signed:0
diag.loopID:125
diag.mode.burnin:0
diag.mode.burnin.0.name:verify
diag.mode.burnin.level:0
diag.mode.esd:0
diag.mode.lab:0
diag.mode.mfg:0
diag.postDisable:0
diag.retryDisable:0
diag.test.crossPort.passes:5000
diag.test.passes:0
diag.test.portLoopback.passes:1000
diag.test.silkScreen.passes:180
diag.test.spinSilk.passes:120
dsim.mode:0
fabric.domain:1
fabric.ididmode:0
fabric.ops.BBCredit:16
fabric.ops.E_D_TOV:2000
fabric.ops.R_A_TOV:10000
fabric.ops.bladeFault_on_hwErrlevel:0
fabric.ops.dataFieldSize:2112
fabric.ops.max_hops:7
fabric.ops.mode.fcpProbeDisable:0
fabric.ops.mode.isolate:0
fabric.ops.mode.longDistance:0
fabric.ops.mode.noClassF:0
fabric.ops.mode.pidFormat:1
fabric.ops.mode.tachyonCompat:0
fabric.ops.mode.unicastOnly:0
fabric.ops.mode.useCsCtl:0
fabric.ops.vc.class.2:2
fabric.ops.vc.class.3:3
fabric.ops.vc.config:0xc0
fabric.ops.vc.linkCtrl:0
fabric.ops.vc.multicast:7
fabric.ops.wan_tov:0
fabric.principalSwSelMode:0
fc4.fcp.productId:FC Switch
fc4.fcp.vendorId:BROCADE
fcAL.alwaysSendRSCN:1
fcAL.fanFrameDisable:0
fcAL.openSendCLS:0
fcAL.useAltBBCredit:0
fdd.acceptcfg.auth:1
fdd.acceptcfg.dcc:1
fdd.acceptcfg.fcs:1
fdd.acceptcfg.ipf:1
fdd.acceptcfg.pwd:1
fdd.acceptcfg.scc:1
fdd.fabwidecfg:
fdd.hash.dcc:
fdd.hash.fbw:
fdd.hash.pwd:
fdd.hash.scc:
fdd.hashpresent.dcc:0
fdd.hashpresent.fbw:0
fdd.hashpresent.fcs:0
fdd.hashpresent.pwd:0
fdd.hashpresent.scc:0
featuredb.status:1
ficu.EBCDICcodePage:37
ficu.MIHPTO:15
ficu.fmsmode:0
fips.mode:0
fips.promallow:1
fips.selftests:0
flannel.ops.frameColMethod:piling
flannel.ops.openBBCredit:4
gen.fabos:0
gen.zone:0
http.accesslog.enabled:0
http.enabled:1
http.errorlog.enabled:0
http.isalivecheck.enabled:1
http.lookupName:.251
http.maxheapsize:256
http.port:80
http.ssl.enabled:0
http.ssl.port:443
http.ssllog.enabled:0
http.switchexplorer.isMainRightFrameEnabled:1
ipfilter.0.name:default_ipv4
ipfilter.0.numofrules:12
ipfilter.0.rule.1:0,0x23,0,0,6,22
ipfilter.0.rule.10:0,0x23,0,0,17,123
ipfilter.0.rule.11:0,0x63,0,0,6,600,1023
ipfilter.0.rule.12:0,0x63,0,0,17,600,1023
ipfilter.0.rule.2:0,0x23,0,0,6,23
ipfilter.0.rule.3:0,0x23,0,0,6,897
ipfilter.0.rule.4:0,0x23,0,0,6,898
ipfilter.0.rule.5:0,0x23,0,0,6,111
ipfilter.0.rule.6:0,0x23,0,0,6,80
ipfilter.0.rule.7:0,0x23,0,0,6,443
ipfilter.0.rule.8:0,0x23,0,0,17,161
ipfilter.0.rule.9:0,0x23,0,0,17,111
ipfilter.0.state:3
ipfilter.0.type:0
ipfilter.1.name:default_ipv6
ipfilter.1.numofrules:12
ipfilter.1.rule.1:0,0x23,0,0,6,22
ipfilter.1.rule.10:0,0x23,0,0,17,123
ipfilter.1.rule.11:0,0x63,0,0,6,600,1023
ipfilter.1.rule.12:0,0x63,0,0,17,600,1023
ipfilter.1.rule.2:0,0x23,0,0,6,23
ipfilter.1.rule.3:0,0x23,0,0,6,897
ipfilter.1.rule.4:0,0x23,0,0,6,898
ipfilter.1.rule.5:0,0x23,0,0,6,111
ipfilter.1.rule.6:0,0x23,0,0,6,80
ipfilter.1.rule.7:0,0x23,0,0,6,443
ipfilter.1.rule.8:0,0x23,0,0,17,161
ipfilter.1.rule.9:0,0x23,0,0,17,111
ipfilter.1.state:3
ipfilter.1.type:1
lsportCfg:0,0x10000000;1,0x10000000;2,0x10000000;3,0x10000000;4,0x10000000;5,0x10000000;6,0x10000000;7,0x10000000;8,0x10000000;9,0x10000000;10,0x10000000;11,0x10000000;12,0x10000000;13,0x10000000;14,0x10000000;15,0x10000000;16,0x10000000;17,0x10000000;18,0x10000000;19,0x10000000;20,0x10000000;21,0x10000000;22,0x10000000;23,0x10000000;24,0x10000000;25,0x10000000;26,0x10000000;27,0x10000000;28,0x10000000;29,0x10000000;30,0x10000000;31,0x10000000;
ms.PlatEnable:0
ms.TDEnable:0
ns.DomRscnToDevForSwChg.enable:0
ns.EndDeviceRscnFormat:1
oemLogo:1
passwdcfg.adminlockout:0
passwdcfg.digits:0
passwdcfg.history:1
passwdcfg.lockoutduration:30
passwdcfg.lockoutthreshold:0
passwdcfg.lowercase:0
passwdcfg.maxpasswordage:0
passwdcfg.minlength:8
passwdcfg.minpasswordage:0
passwdcfg.punctuation:0
passwdcfg.repeat:1
passwdcfg.sequence:1
passwdcfg.status:0
passwdcfg.uppercase:0
passwdcfg.warning:0
perf.cfgver:2
perf.eemonchks:0
perf.eemskchks:0
perf.fltmonchks:0
quickLoop.holdOpenInit:0
quickLoop.noAlpaZero:0
quickLoop.peerWWN:00:00:00:00:00:00:00:00
quickLoop.portBitmap:0x0000000000000000
quickLoop.softInit:0
rasm.filter:5
rlsDisable:1
route.delayReroute:1
route.embeddedPortBcast:1
route.stickyRoutes:1
rpcd.callback.enabled:0
rpcd.callback.secret:secret
rpcd.enabled:1
rpcd.ssl.enabled:0
rte.external_policy:1
rte.internal_policy:0
sec.fstov:5000
sec.mode:0
sec.versionStamp:0
secrpc.enabled:0
shell.delete:0
shell.quiet:0
snmp.accessList.0.address:0.0.0.0
snmp.accessList.0.address_v6:0:0:0:0:0:0:0:0/0
snmp.accessList.0.rw:1
snmp.accessList.1.address:0.0.0.0
snmp.accessList.1.address_v6:0:0:0:0:0:0:0:0/0
snmp.accessList.1.rw:1
snmp.accessList.2.address:0.0.0.0
snmp.accessList.2.address_v6:0:0:0:0:0:0:0:0/0
snmp.accessList.2.rw:1
snmp.accessList.3.address:0.0.0.0
snmp.accessList.3.address_v6:0:0:0:0:0:0:0:0/0
snmp.accessList.3.rw:1
snmp.accessList.4.address:0.0.0.0
snmp.accessList.4.address_v6:0:0:0:0:0:0:0:0/0
snmp.accessList.4.rw:1
snmp.accessList.5.address:0.0.0.0
snmp.accessList.5.address_v6:0:0:0:0:0:0:0:0/0
snmp.accessList.5.rw:1
snmp.agtParty.0.address:0.0.0.0
snmp.agtParty.0.address_v6:0:0:0:0:0:0:0:0
snmp.agtParty.0.authPrivSecret:Secret C0de
snmp.agtParty.0.index:1
snmp.agtParty.0.port:162
snmp.agtParty.0.trapSeverityLevel:0
snmp.agtParty.1.address:0.0.0.0
snmp.agtParty.1.address_v6:0:0:0:0:0:0:0:0
snmp.agtParty.1.authPrivSecret:OrigEquipMfr
snmp.agtParty.1.index:2
snmp.agtParty.1.port:162
snmp.agtParty.1.trapSeverityLevel:0
snmp.agtParty.2.address:0.0.0.0
snmp.agtParty.2.address_v6:0:0:0:0:0:0:0:0
snmp.agtParty.2.authPrivSecret:private
snmp.agtParty.2.index:3
snmp.agtParty.2.port:162
snmp.agtParty.2.trapSeverityLevel:0
snmp.agtParty.3.address:0.0.0.0
snmp.agtParty.3.address_v6:0:0:0:0:0:0:0:0
snmp.agtParty.3.authPrivSecret:public
snmp.agtParty.3.index:4
snmp.agtParty.3.port:162
snmp.agtParty.3.trapSeverityLevel:0
snmp.agtParty.4.address:0.0.0.0
snmp.agtParty.4.address_v6:0:0:0:0:0:0:0:0
snmp.agtParty.4.authPrivSecret:common
snmp.agtParty.4.index:5
snmp.agtParty.4.port:162
snmp.agtParty.4.trapSeverityLevel:0
snmp.agtParty.5.address:0.0.0.0
snmp.agtParty.5.address_v6:0:0:0:0:0:0:0:0
snmp.agtParty.5.authPrivSecret:FibreChannel
snmp.agtParty.5.index:6
snmp.agtParty.5.port:162
snmp.agtParty.5.trapSeverityLevel:0
snmp.authentTraps:1
snmp.mibCap:2089191
snmp.seclevel:0
snmp.setseclevel:0
snmp.snmpv3EngineBoots:11
snmp.snmpv3TrapTarget.0.trapSeverityLevel:0
snmp.snmpv3TrapTarget.0.trapTargetAddr:0.0.0.0
snmp.snmpv3TrapTarget.0.trapTargetAddr_v6:0:0:0:0:0:0:0:0
snmp.snmpv3TrapTarget.0.trapTargetIndex:1
snmp.snmpv3TrapTarget.0.trapUsmIndex:1
snmp.snmpv3TrapTarget.1.trapSeverityLevel:0
snmp.snmpv3TrapTarget.1.trapTargetAddr:0.0.0.0
snmp.snmpv3TrapTarget.1.trapTargetAddr_v6:0:0:0:0:0:0:0:0
snmp.snmpv3TrapTarget.1.trapTargetIndex:2
snmp.snmpv3TrapTarget.1.trapUsmIndex:2
snmp.snmpv3TrapTarget.2.trapSeverityLevel:0
snmp.snmpv3TrapTarget.2.trapTargetAddr:0.0.0.0
snmp.snmpv3TrapTarget.2.trapTargetAddr_v6:0:0:0:0:0:0:0:0
snmp.snmpv3TrapTarget.2.trapTargetIndex:3
snmp.snmpv3TrapTarget.2.trapUsmIndex:3
snmp.snmpv3TrapTarget.3.trapSeverityLevel:0
snmp.snmpv3TrapTarget.3.trapTargetAddr:0.0.0.0
snmp.snmpv3TrapTarget.3.trapTargetAddr_v6:0:0:0:0:0:0:0:0
snmp.snmpv3TrapTarget.3.trapTargetIndex:4
snmp.snmpv3TrapTarget.3.trapUsmIndex:4
snmp.snmpv3TrapTarget.4.trapSeverityLevel:0
snmp.snmpv3TrapTarget.4.trapTargetAddr:0.0.0.0
snmp.snmpv3TrapTarget.4.trapTargetAddr_v6:0:0:0:0:0:0:0:0
snmp.snmpv3TrapTarget.4.trapTargetIndex:5
snmp.snmpv3TrapTarget.4.trapUsmIndex:5
snmp.snmpv3TrapTarget.5.trapSeverityLevel:0
snmp.snmpv3TrapTarget.5.trapTargetAddr:0.0.0.0
snmp.snmpv3TrapTarget.5.trapTargetAddr_v6:0:0:0:0:0:0:0:0
snmp.snmpv3TrapTarget.5.trapTargetIndex:6
snmp.snmpv3TrapTarget.5.trapUsmIndex:6
snmp.snmpv3Usm.0.usmAuthProtocol:3
snmp.snmpv3Usm.0.usmAuthSecret:adminpasswd1
snmp.snmpv3Usm.0.usmIndex:1
snmp.snmpv3Usm.0.usmPrivProtocol:2
snmp.snmpv3Usm.0.usmPrivSecret:adminpasswd1
snmp.snmpv3Usm.0.usmUserName:snmpadmin1
snmp.snmpv3Usm.1.usmAuthProtocol:3
snmp.snmpv3Usm.1.usmAuthSecret:adminpasswd2
snmp.snmpv3Usm.1.usmIndex:2
snmp.snmpv3Usm.1.usmPrivProtocol:2
snmp.snmpv3Usm.1.usmPrivSecret:adminpasswd2
snmp.snmpv3Usm.1.usmUserName:snmpadmin2
snmp.snmpv3Usm.2.usmAuthProtocol:3
snmp.snmpv3Usm.2.usmAuthSecret:adminpasswd3
snmp.snmpv3Usm.2.usmIndex:3
snmp.snmpv3Usm.2.usmPrivProtocol:2
snmp.snmpv3Usm.2.usmPrivSecret:adminpasswd3
snmp.snmpv3Usm.2.usmUserName:snmpadmin3
snmp.snmpv3Usm.3.usmAuthProtocol:3
snmp.snmpv3Usm.3.usmAuthSecret:userpasswd1
snmp.snmpv3Usm.3.usmIndex:4
snmp.snmpv3Usm.3.usmPrivProtocol:2
snmp.snmpv3Usm.3.usmPrivSecret:userpasswd1
snmp.snmpv3Usm.3.usmUserName:snmpuser1
snmp.snmpv3Usm.4.usmAuthProtocol:3
snmp.snmpv3Usm.4.usmAuthSecret:userpasswd2
snmp.snmpv3Usm.4.usmIndex:5
snmp.snmpv3Usm.4.usmPrivProtocol:2
snmp.snmpv3Usm.4.usmPrivSecret:userpasswd2
snmp.snmpv3Usm.4.usmUserName:snmpuser2
snmp.snmpv3Usm.5.usmAuthProtocol:3
snmp.snmpv3Usm.5.usmAuthSecret:userpasswd3
snmp.snmpv3Usm.5.usmIndex:6
snmp.snmpv3Usm.5.usmPrivProtocol:2
snmp.snmpv3Usm.5.usmPrivSecret:userpasswd3
snmp.snmpv3Usm.5.usmUserName:snmpuser3
snmp.sysContact:Field Support.
snmp.sysDescription:Fibre Channel Switch.
snmp.sysLocation:End User Premise.
snmp.sysObjectID:1588.2.1.1.58
snmp.sysObjectID.default:1588.2.1.1.58
snmp.trapEnterpriseFlag:0
ssl.certfile:none
ssl.crypto.length:128
ssl.keyfile:pvt_key
ssl.root.certfile:none
ssn:USB731LN10
switch.domain_id_offset:96
switch.interopMode:0
switch.largeEntry.cap:0
switch.mail.agent_3.item_112:
switch.mail.agent_3.item_113:0
switch.mcdtDefaultZone:0
switch.mcdtFabricMode:0
switch.mcdtSafeZone:0
switch.status.policy.Fans.down:2
switch.status.policy.Fans.marginal:1
switch.status.policy.FaultyPorts.down:2
switch.status.policy.FaultyPorts.marginal:1
switch.status.policy.Flash.down:0
switch.status.policy.Flash.marginal:1
switch.status.policy.MarginalPorts.down:2
switch.status.policy.MarginalPorts.marginal:1
switch.status.policy.MissingSFPs.down:0
switch.status.policy.MissingSFPs.marginal:0
switch.status.policy.PowerSupplies.down:2
switch.status.policy.PowerSupplies.marginal:1
switch.status.policy.Temperatures.down:2
switch.status.policy.Temperatures.marginal:1
syslog.address.1:.141
system.blade.bladeFaultOnHwErrMsk:0x0
system.login.timeout:600
thresh.alarmsfilter:1
trace.dump.datetime.s0:1234750667
trace.dump.ftpflag.s0:0
trace.ftp.enableflag:0
trace.ftp.hostname:
trace.ftp.password:
trace.ftp.period:0
trace.ftp.remotedir:
trace.ftp.username:
ts.clockServer:LOCL
ts.clockServerList:LOCL
ts.tzh:0
ts.tzm:0
webtools.basicuser.enabled:0
webtools.fabricevents.enabled:1
webtools.initiatorports:none
webtools.licensecheck.enabled:1
webtools.max.session:50
webtools.max.zonetxn:50
webtools.session.ttl:7200
webtools.targetports:none
webtools.upfrontlogin.enabled:0
webtools.zonetxn.ttl:600
xlativeModeDisable:0
zoning.check.nodeNameDisabled:0
zoning.standardMode:0
cfg.qcisapcfg1:BWDEV1_H0_CX320_SPA_4_CX320_SPB_4;BWDEV1_H1_CX320_SPA_4_CX320_SPB_4;dl9801_eva1f1_tccqas2;dl9801_eva2f1_for_CA;dl9802_eva1f1;dl9802_eva2f1_for_CA;eva_caf1;PC1_LTO2;PC1_LTO3;PC2_LTO2;PC2_LTO3;QCISMD1_H0_CX320_SPA_4_CX320_SPB_4;QCISMD1_H1_CX320_SPA_4_CX320_SPB_4;QCNPRD2_A_CX320_SPA_4_SPB_4;QCNPRD2_B_CX320_SPA_5_SPB_5;sd1_LTO3;sma_eva1f1;sma_eva2f1;SMA_EVA8K4_prd;tccdbm1_eva1f1_rf2;tccdev1_new_rf2;tccqas1_eva1f1_rf2;tccqas1_EVA2;tccqas1ANDtccdbm1_eva2f1_rf2;tccqas2_eva1f1_rf2;TFCPRD2_H0_CX320_SPA_4_CX320_SPB_4;TFCPRD2_H0_CX320_SPA_5_CX320_SPB_5;TFCPRD2_H1_CX320_SPA_4_CX320_SPB_4;TFCPRD2_H1_CX320_SPA_5_CX320_SPB_5;VMWARE;z218f1;z218s_f1;z268f1;z318f1;z368f1;zsapdaf1
zone.BWDEV1_H0_CX320_SPA_4_CX320_SPB_4:BWDEV1_H0;CX320_SPA_4;CX320_SPB_4
zone.BWDEV1_H1_CX320_SPA_4_CX320_SPB_4:BWDEV1_H1;CX320_SPA_4;CX320_SPB_4
zone.PC1_LTO2:LTO2;PC1
zone.PC1_LTO3:LTO3;PC1
zone.PC2_LTO2:LTO2;PC2
zone.PC2_LTO3:LTO3;PC2
zone.QCISMD1_H0_CX320_SPA_4_CX320_SPB_4:CX320_SPA_4;CX320_SPB_4;QCISMD1_H0
zone.QCISMD1_H1_CX320_SPA_4_CX320_SPB_4:CX320_SPA_4;CX320_SPB_4;QCISMD1_H1
zone.QCNPRD2_A_CX320_SPA_4_SPB_4:CX320_SPA_4;CX320_SPB_4
zone.QCNPRD2_B_CX320_SPA_5_SPB_5:CX320_SPA_5;CX320_SPB_5
zone.SMA_EVA8K4_prd:EVA8K4_prd_a1;EVA8K4_prd_b1;EVA_SMA1_A
zone.TFCPRD2_H0_CX320_SPA_4_CX320_SPB_4:CX320_SPA_4;CX320_SPB_4;TFCPRD2_H0
zone.TFCPRD2_H0_CX320_SPA_5_CX320_SPB_5:CX320_SPA_5;CX320_SPB_5;TFCPRD2_H0
zone.TFCPRD2_H1_CX320_SPA_4_CX320_SPB_4:CX320_SPA_4;CX320_SPB_4;TFCPRD2_H1
zone.TFCPRD2_H1_CX320_SPA_5_CX320_SPB_5:CX320_SPA_5;CX320_SPB_5;TFCPRD2_H1
zone.VMWARE:QCIESX01;QCIESX02;VMSTORAGE01;VMSTORAGE02
zone.dl9801_eva1f1_tccqas2:dl980_1;EVA8K1DBM_prd_a1;EVA8K1DBM_prd_b1;EVA8K2QAS_stb_a1;EVA8K2QAS_stb_b1;EVA8K4_prd_a1;EVA8K4_prd_a3;EVA8K4_prd_b1;EVA8K4_prd_b3;rf2_logshipp;sd1_A;sd1_C;tccdbm1;tccqas2
zone.dl9801_eva2f1_for_CA:EVA8K2QAS_stb_a1;EVA8K2QAS_stb_b1;sd1_A;sd1_C
zone.dl9802_eva1f1:dl980_2;EVA8K1DBM_prd_a1;EVA8K1DBM_prd_b1;EVA8K2QAS_stb_a1;EVA8K2QAS_stb_b1;EVA8K4_prd_a1;EVA8K4_prd_a3;EVA8K4_prd_b1;EVA8K4_prd_b3;rf2_logshipp
zone.dl9802_eva2f1_for_CA:EVA8K2QAS_stb_a1;EVA8K2QAS_stb_b1;sd2_A;sd2_C
zone.eva_caf1:EVA8K1DBM_prd_a3;EVA8K1DBM_prd_b3
zone.sd1_LTO3:LTO3;sd1_A
zone.sma_eva1f1:EVA8K1DBM_prd_a1;EVA8K1DBM_prd_b1;EVA_SMA1_A
zone.sma_eva2f1:EVA8K2QAS_stb_a1;EVA8K2QAS_stb_b1;EVA_SMA1_A
zone.tccdbm1_eva1f1_rf2:EVA8K1DBM_prd_a1;EVA8K1DBM_prd_b1;rf2_logshipp;sd2_A;sd2_C;tccdbm1;tccqas2
zone.tccdev1_new_rf2:EVA8K1DBM_prd_a1;EVA8K1DBM_prd_b1;EVA8K2QAS_stb_a1;EVA8K2QAS_stb_b1;rf2_logshipp;tccdev1_new
zone.tccqas1ANDtccdbm1_eva2f1_rf2:EVA8K2QAS_stb_a1;EVA8K2QAS_stb_b1;RF2_QAS;tccdbm1;tccqas1
zone.tccqas1_EVA2:EVA8K2QAS_stb_a1;EVA8K2QAS_stb_b1;tccqas1
zone.tccqas1_eva1f1_rf2:EVA8K1DBM_prd_a1;EVA8K1DBM_prd_b1;RF2_QAS;tccqas1
zone.tccqas2_eva1f1_rf2:EVA8K1DBM_prd_a1;EVA8K1DBM_prd_b1;rf2_logshipp;tccqas2
zone.z218f1:Shark_218_268_A;Shark_218_268_C;Shark_218_A;Shark_218_C;tccprd3_A;tccprd3_C
zone.z218s_f1:CX320_SPA_4;CX320_SPA_5
zone.z268f1:Shark_268_A;Shark_268_C;tfcprd1_A;tfcprd1_C
zone.z318f1:EVA44K1_prd_a1;EVA44K1_prd_a2;EVA44K2_stb_b1;EVA44K2_stb_b2;QCNPRD1_A;QCNPRD1_B;QCNPRD2_A;QCNPRD2_B
zone.z368f1:DNS3100_A;DNS3100_C;qcaprd3;qcaprd9_A;qcaprd9_B
zone.zsapdaf1:DNS3100_A;DNS3100_C;SAPDA01_A;SAPDA01_B
alias.BWDEV1_H0:3,9
alias.BWDEV1_H1:3,16
alias.CX320_SPA_4:3,0
alias.CX320_SPA_5:3,4
alias.CX320_SPB_4:3,1
alias.CX320_SPB_5:3,5
alias.DNS3100_A:3,8
alias.DNS3100_C:3,12
alias.EVA44K1_prd_a1:3,18
alias.EVA44K1_prd_a2:3,25
alias.EVA44K2_stb_b1:3,22
alias.EVA44K2_stb_b2:3,29
alias.EVA8K1DBM_prd_a1:1,16
alias.EVA8K1DBM_prd_a3:1,17
alias.EVA8K1DBM_prd_b1:1,18
alias.EVA8K1DBM_prd_b3:1,19
alias.EVA8K2QAS_stb_a1:1,24
alias.EVA8K2QAS_stb_b1:1,26
alias.EVA8K4_prd_a1:1,28
alias.EVA8K4_prd_a3:1,11
alias.EVA8K4_prd_b1:1,29
alias.EVA8K4_prd_b3:1,30
alias.EVA_SMA1_A:1,14
alias.LTO2:5,6;5,7
alias.LTO3:5,2;5,4
alias.PC1:5,0
alias.PC2:5,1
alias.QCIESX01:20:00:00:1b:32:9b:6a:fe
alias.QCIESX02:20:00:00:e0:8b:85:4c:1f
alias.QCISMD1_H0:3,13
alias.QCISMD1_H1:3,11
alias.QCNPRD1_A:3,17
alias.QCNPRD1_B:3,24
alias.QCNPRD2_A:3,21
alias.QCNPRD2_B:3,28
alias.RF2_QAS:3,23
alias.SAPDA01_A:1,9
alias.SAPDA01_B:1,13
alias.Shark_218_268_A:1,8
alias.Shark_218_268_C:1,12
alias.Shark_218_A:1,0
alias.Shark_218_C:1,4
alias.Shark_268_A:1,2
alias.Shark_268_C:1,6
alias.TFCPRD2_H0:3,2
alias.TFCPRD2_H1:3,6
alias.VMSTORAGE01:3,15
alias.VMSTORAGE02:3,14
alias.dl980_1:1,17;1,19
alias.dl980_2:1,25;1,27
alias.qcaprd3:1,30
alias.qcaprd9_A:1,28
alias.qcaprd9_B:1,29
alias.rf2_logshipp:50:01:63:60:00:5d:ff:c2;50:01:63:60:00:5d:ff:c3;50:01:63:60:00:5e:00:3a;50:01:63:60:00:5e:00:3b
alias.sd1_A:1,20
alias.sd1_C:1,21
alias.sd2_A:1,22
alias.sd2_C:1,23
alias.tccdbm1:1,15;1,20
alias.tccdev1_new:3,26;3,30
alias.tccprd3_A:1,1
alias.tccprd3_C:1,5
alias.tccqas1:1,10
alias.tccqas2:1,23
alias.tfcprd1_A:1,3
alias.tfcprd1_C:1,7
defzone:allaccess
enable:qcisapcfg1
Anonymous
-- SW2 -- SW1's redundent path
boot.name:QCISAPSW2
boot.ipa:.252
boot.licid:10:00:00:05:1e:90:19:33
boot.mac:10:00:00:05:1e:90:19:33
boot.device:eth0
50629A9D0D70DB17132C039E5370B37B50629A9D0D70DB174A7C6D714DE0AA4842B0
byRbzbybeyqzSc0F
SbzbRbyybzTs4cSe
acl.clear:0
alpaList:1
auth.policy:0
auth.policy.dev:3
cfgload.secure:0
cfgload.signed:0
diag.loopID:125
diag.mode.burnin:0
diag.mode.esd:0
diag.mode.lab:0
diag.mode.mfg:0
diag.postDisable:0
diag.retryDisable:0
diag.test.passes:0
dsim.mode:0
fabric.domain:2
fabric.ididmode:0
fcAL.openSendCLS:0
fdd.acceptcfg.dcc:1
fdd.acceptcfg.fcs:1
fdd.acceptcfg.ipf:1
fdd.acceptcfg.pwd:1
fdd.acceptcfg.scc:1
fdd.fabwidecfg:
fdd.hash.dcc:
fdd.hash.fbw:
fdd.hash.pwd:
fdd.hash.scc:
featuredb.status:1
ficu.MIHPTO:15
ficu.fmsmode:0
fips.mode:0
fips.promallow:1
fips.selftests:0
gen.fabos:0
gen.zone:0
http.enabled:1
http.lookupName:.252
http.port:80
http.ssl.enabled:0
http.ssl.port:443
ipfilter.0.state:3
ipfilter.0.type:0
ipfilter.1.state:3
ipfilter.1.type:1
ms.PlatEnable:0
ms.TDEnable:0
oemLogo:1
passwdcfg.digits:0
passwdcfg.history:1
passwdcfg.repeat:1
passwdcfg.status:0
passwdcfg.warning:0
perf.cfgver:2
perf.eemonchks:0
perf.eemskchks:0
perf.fltmonchks:0
rasm.filter:5
rlsDisable:1
rpcd.enabled:1
rpcd.ssl.enabled:0
sec.fstov:5000
sec.mode:0
sec.versionStamp:0
secrpc.enabled:0
shell.delete:0
shell.quiet:0
snmp.authentTraps:1
snmp.mibCap:2089191
snmp.seclevel:0
snmp.setseclevel:0
ssl.certfile:none
ssl.keyfile:pvt_key
ssn:USB731LN0S
trace.dump.datetime.s0:1234750146
trace.ftp.hostname:
trace.ftp.password:
trace.ftp.period:0
trace.ftp.username:
ts.clockServer:LOCL
ts.tzh:0
ts.tzm:0
cfg.qcisapcfg2:eva_caf2;rx26_eva1f2;rx26_eva2f2;sd1_eva1f2;sd1_eva2f2_for_CA;sd2_eva1f2;sd2_eva2f2_for_CA;sma_eva1f2;sma_eva2f2;SMA_EVA8K4_prd_2;z218f2;z268f2
zone.SMA_EVA8K4_prd_2:EVA8K4_prd_a2;EVA8K4_prd_b2;EVA_SMA1_B
zone.eva_caf2:EVA8K1DBM_prd_a4;EVA8K1DBM_prd_b4
zone.rx26_eva1f2:EVA8K1DBM_prd_a2;EVA8K1DBM_prd_b2;rx26_B_tccqas1
zone.rx26_eva2f2:EVA8K2QAS_stb_a2;EVA8K2QAS_stb_b2;rx26_B_tccqas1
zone.sd1_eva1f2:dl980_1;EVA8K1DBM_prd_a2;EVA8K1DBM_prd_b2;EVA8K4_prd_a2;EVA8K4_prd_a4;EVA8K4_prd_b2;EVA8K4_prd_b4
zone.sd1_eva2f2_for_CA:EVA8K2QAS_stb_a2;EVA8K2QAS_stb_b2;sd1_B;sd1_D
zone.sd2_eva1f2:dl980_2;EVA8K1DBM_prd_a2;EVA8K1DBM_prd_b2;EVA8K4_prd_a2;EVA8K4_prd_a4;EVA8K4_prd_b2;EVA8K4_prd_b4
zone.sd2_eva2f2_for_CA:EVA8K2QAS_stb_a2;EVA8K2QAS_stb_b2;sd2_B;sd2_D
zone.sma_eva1f2:EVA8K1DBM_prd_a2;EVA8K1DBM_prd_b2;EVA_SMA1_B
zone.sma_eva2f2:EVA8K2QAS_stb_a2;EVA8K2QAS_stb_b2;EVA_SMA1_B
zone.tccqas2_EVA8K1DBM_rf2:EVA8K1DBM_prd_a2;EVA8K1DBM_prd_a4;EVA8K1DBM_prd_b2;EVA8K1DBM_prd_b4;EVA8K2QAS_stb_a2;EVA8K2QAS_stb_b2;tccqas2
zone.z218f2:Shark_218_268_B;Shark_218_268_D;Shark_218_B;Shark_218_D;tccprd3_B;tccprd3_D
zone.z268f2:Shark_268_B;Shark_268_D;tfcprd1_B;tfcprd1_D
alias.EVA8K1DBM_prd_a2:2,16
alias.EVA8K1DBM_prd_a4:2,17
alias.EVA8K1DBM_prd_b2:2,18
alias.EVA8K1DBM_prd_b4:2,19
alias.EVA8K2QAS_stb_a2:2,24
alias.EVA8K2QAS_stb_b2:2,26
alias.EVA8K4_prd_a2:2,28
alias.EVA8K4_prd_a4:2,11
alias.EVA8K4_prd_b2:2,29
alias.EVA8K4_prd_b4:2,30
alias.EVA_SMA1_B:2,14
alias.Shark_218_268_B:2,8
alias.Shark_218_268_D:2,12
alias.Shark_218_B:2,0
alias.Shark_218_D:2,4
alias.Shark_268_B:2,2
alias.Shark_268_D:2,6
alias.dl980_1:2,17;2,19
alias.dl980_2:2,25;2,27
alias.rx26_B_tccqas1:2,15
alias.sd1_B:2,20
alias.sd1_D:2,21
alias.sd2_B:2,22
alias.sd2_D:2,23
alias.tccprd3_B:2,1
alias.tccprd3_D:2,5
alias.tccqas2:2,21
alias.tfcprd1_B:2,3
alias.tfcprd1_D:2,7
defzone:allaccess
enable:qcisapcfg2
Anonymous
-- SW3 -- trunked with SW1 for DR site
boot.name:QCISAPSW3
boot.ipa:.251
boot.licid:10:00:00:05:1e:90:19:26
boot.mac:10:00:00:05:1e:90:19:26
boot.device:eth0
6D796883287977672AAEC1CE19362D306D7968832879776770E4338407A6341673ED
SRRS9ySQRehSSTA4
yzSSySbzyzGXTz3
telnetd:1
acl.clear:0
alpaList:1
auth.policy:0
auth.policy.dev:3
cfgload.secure:0
cfgload.signed:0
diag.loopID:125
diag.mode.burnin:0
diag.mode.esd:0
diag.mode.lab:0
diag.mode.mfg:0
diag.postDisable:0
diag.retryDisable:0
diag.test.passes:0
dsim.mode:0
fabric.domain:3
fabric.ididmode:0
fcAL.openSendCLS:0
fdd.acceptcfg.dcc:1
fdd.acceptcfg.fcs:1
fdd.acceptcfg.ipf:1
fdd.acceptcfg.pwd:1
fdd.acceptcfg.scc:1
fdd.fabwidecfg:
fdd.hash.dcc:
fdd.hash.fbw:
fdd.hash.pwd:
fdd.hash.scc:
featuredb.status:1
ficu.MIHPTO:15
ficu.fmsmode:0
fips.mode:0
fips.promallow:1
fips.selftests:0
gen.fabos:0
gen.zone:0
http.enabled:1
http.port:80
http.ssl.enabled:0
http.ssl.port:443
ipfilter.0.state:3
ipfilter.0.type:0
ipfilter.1.state:3
ipfilter.1.type:1
ms.PlatEnable:0
ms.TDEnable:0
oemLogo:1
passwdcfg.digits:0
passwdcfg.history:1
passwdcfg.repeat:1
passwdcfg.status:0
passwdcfg.warning:0
perf.cfgver:2
perf.eemonchks:0
perf.eemskchks:0
perf.fltmonchks:0
rasm.filter:5
rlsDisable:1
route.stickyRoutes:0
rpcd.enabled:1
rpcd.ssl.enabled:0
sec.fstov:5000
sec.mode:0
sec.versionStamp:0
secrpc.enabled:0
shell.delete:0
shell.quiet:0
snmp.authentTraps:1
snmp.mibCap:2089191
snmp.seclevel:0
snmp.setseclevel:0
snmp.snmpv3EngineBoots:14
ssl.certfile:none
ssl.keyfile:pvt_key
ssn:USB731LN1A
trace.dump.datetime.s0:0
trace.ftp.hostname:
trace.ftp.password:
trace.ftp.period:0
trace.ftp.username:
ts.clockServer:LOCL
ts.tzh:0
ts.tzm:0
alias.BWDEV1_H0:3,9
alias.DNS3100_A:3,8
alias.LTO2:5,6;5,7
alias.LTO3:5,2;5,4
alias.PC1:5,0
alias.PC2:5,1
alias.RF2_QAS:3,23
alias.SAPDA01_A:1,9
alias.qcaprd3:1,30
alias.sd1_A:1,20
alias.sd1_C:1,21
alias.sd2_A:1,22
alias.sd2_C:1,23
alias.tccprd3_A:1,1
alias.tccprd3_C:1,5
alias.tccqas1:1,10
alias.tccqas2:1,23
alias.tfcprd1_A:1,3
alias.tfcprd1_C:1,7
defzone:allaccess
enable:qcisapcfg1
消息编辑者为:Dennis Lee
Anonymous
Hi Dennis, maybe you want to remove specific details like switch ip address and email address.
A cfgshow would suffice to check.
That said, the messages from the webGUI state you should be looking in the qcisapcfg1 and sd1_eva1f1, sd2_eva1f1, tccqas1_eva2 and d980_rf2_logship.
However if I look into the pasted qcisapcfg1 zoneconfig a fail to find the stated objects.
Can you check if you see the same errors on the CLI with errshow or errdump?
They should also appear if you enable a config on the commandline.
If these errors do not appear I think it has to do with the webgui making a mess of it.
Anonymous
Hi dion,
   Thanks for your reply. I understand a little bit right now. I run cfgenable and errdump in CLI and find there are two duplicate zone entries but this does not show in cfgshow.
2013/09/05-03:01:24, , 2506,, INFO, QCISAPSW1, The effective configuration has changed to qcisapcfg1.
2013/09/05-03:04:19, , 2507,, INFO, QCISAPSW1, Login information: Login successful via TELNET/SSH/RSH. IP Addr: x.x.x.x
2013/09/05-03:04:34, , 2508,, WARNING, QCISAPSW1, WARNING - Duplicate entries in zone(dl9801_eva1f1_tccqas2) specification.
2013/09/05-03:04:34, , 2509,, WARNING, QCISAPSW1, WARNING - Duplicate entries in zone(tccdbm1_eva1f1_rf2) specification.
2013/09/05-03:04:35, , 2510,, INFO, QCISAPSW1, The effective configuration has changed to qcisapcfg1.
Effective configuration:
cfg: qcisapcfg1
zone: BWDEV1_H0_CX320_SPA_4_CX320_SPB_4
  3,9
  3,0
  3,1
zone: BWDEV1_H1_CX320_SPA_4_CX320_SPB_4
  3,16
  3,0
  3,1
zone: PC1_LTO2
  5,6
  5,7
  5,0
zone: PC1_LTO3
  5,2
  5,4
  5,0
zone: PC2_LTO2
  5,6
  5,7
  5,1
zone: PC2_LTO3
  5,2
  5,4
  5,1
zone: QCISMD1_H0_CX320_SPA_4_CX320_SPB_4
  3,0
  3,1
  3,13
zone: QCISMD1_H1_CX320_SPA_4_CX320_SPB_4
  3,0
  3,1
  3,11
zone: QCNPRD2_A_CX320_SPA_4_SPB_4
  3,0
  3,1
zone: QCNPRD2_B_CX320_SPA_5_SPB_5
  3,4
  3,5
zone: SMA_EVA8K4_prd
  1,28
  1,29
  1,14
zone: TFCPRD2_H0_CX320_SPA_4_CX320_SPB_4
  3,0
  3,1
  3,2
zone: TFCPRD2_H0_CX320_SPA_5_CX320_SPB_5
  3,4
  3,5
  3,2
zone: TFCPRD2_H1_CX320_SPA_4_CX320_SPB_4
  3,0
  3,1
  3,6
zone: TFCPRD2_H1_CX320_SPA_5_CX320_SPB_5
  3,4
  3,5
  3,6
zone: VMWARE 20:00:00:1b:32:9b:6a:fe
  3,15
  3,14
zone: dl9801_eva1f1_tccqas2
  1,17
  1,19
  1,16
  1,18
  1,24
  1,26
  1,28
  1,11
  1,29
  1,30
  1,20
  1,21
  1,15
  1,23
zone: dl9801_eva2f1_for_CA
  1,24
  1,26
  1,20
  1,21
zone: dl9802_eva1f1
  1,25
  1,27
  1,16
  1,18
  1,24
  1,26
  1,28
  1,11
  1,29
  1,30
zone: dl9802_eva2f1_for_CA
  1,24
  1,26
  1,22
  1,23
zone: eva_caf1
  1,17
  1,19
zone: sd1_LTO3
  5,2
  5,4
  1,20
zone: sma_eva1f1
  1,16
  1,18
  1,14
zone: sma_eva2f1
  1,24
  1,26
  1,14
zone: tccdbm1_eva1f1_rf2
  1,16
  1,18
  1,22
  1,23
  1,15
  1,20
zone: tccdev1_new_rf2
  1,16
  1,18
  1,24
  1,26
  3,26
  3,30
zone: tccqas1ANDtccdbm1_eva2f1_rf2
  1,24
  1,26
  3,23
  1,15
  1,20
  1,10
zone: tccqas1_EVA2
  1,24
  1,26
  1,10
zone: tccqas1_eva1f1_rf2
  1,16
  1,18
  3,23
  1,10
zone: tccqas2_eva1f1_rf2
  1,16
  1,18
  1,23
zone: z218f1 1,8
  1,12
  1,0
  1,4
  1,1
  1,5
zone: z218s_f1
  3,0
  3,4
zone: z268f1 1,2
  1,6
  1,3
  1,7
zone: z318f1 3,18
  3,25
  3,22
  3,29
  3,17
  3,24
  3,21
  3,28
zone: z368f1 3,8
  3,12
  1,30
  1,28
  1,29
zone: zsapdaf1
  3,8
  3,12
  1,9
  1,13
QCISAPSW1:admin> exit
Anonymous
Hi Dennis,
Most likely the 2 zones contain both the DID,PID and wwpn entry for the same member.
You can check whether or not the mentioned wwpn are visible on the ports that are included as DID,PID.
