Anonymous
Dell Blade Enclosure with SW4016
Hi,
I purchased a Dell Blade Enclosure with an Brocade 4016 .
The formner user missed out to reset the root / admin password to factory default.
How can I do that? The user "user" is working with the default password.
Thanks
Sebastian
External Moderator
Re: Dell Blade Enclosure with SW4016
Sebastian,
is the Blade in a Poweredge 1855 Chassis ?
TechHelp24
TechHelp24
Anonymous
Hi,
yes it is an Poweredge 1855 Chassis.
External Moderator
Connect a serial cable to the PowerEdge 1855 chassis, from a workstation computer.
Please test follow, not sure that work.
Established with a terminal emulator (such as HyperTerminal), power up the Chassis, a stop a boot Procedure from the Blade Switch ,, press here ESC beetwen 4 Seconds to stop POST.
probable you must select a switch bay at the commanf promp, the command is "connect switch-x" x is = 3 or 4 depend the bay is the blade inserted.
here are 3 Option, as follow:
1) Start system.
2) Recover password.
3) Enter command shell.
Option 2 is a Blade Password recovery procedure, WARNING don't use this feature, this PW recovery is only intended for the BOOT Prom Password ( like a BIOS ) and not for the FabOS Password.
Select here Option 3, call the command "printenv" and post here.
give me a result.
TechHelp24
TechHelp24
