Anonymous
DCX-B Power Requirements
Is there a way to tell from the CLI or Webtools if a DCX -B Switch is running at 110V or 220V ?
Also is there a way to tell a Blade to power ratio on the DCX-B. Meaning how many power supplies or power is needed to run so many blades in the switch ?
I know there is a little information n the hardware guide but its very vague .
  http://www.brocade.com/downloads/documents/html_product_manuals/DCX_HRM/wwhelp/wwhimpl/js/html/wwhelp.htm
Thank you in advance .
Valued Contributor
Re: DCX-B Power Requirements
hi, as far as i know, there's no way to tell what is the current PS voltage.
for the blade power consumption, use chassisshow command.
Former Brocadian
The PSU's are auto-sensing and auto-adjusting.  If you refer to the FOS Release Notes, specifically the chapter entitled "Blade Support", it specifies the # of PSU's needed depending on your blade configuration and environmental power.
Regards,
Mike Eversole
Brocade Community Manager
Anonymous
Thanks for the response
I believe Slotshow -p is a useful command as well.
Also the RN is the same info from the hardware guide
External Moderator
go to Power Calculator, and you get the exact answer you need.
http://www.brocade.com/data-center-best-practices/competitive-information/power.page
TechHelp24
