Anonymous
Re: Connecting Two Bracade 300 SAN switches over 2km distance via Single-Mode Fibre?
[ Edited ]
My own attached image works for me, did you perhaps select the private checkbox?
Frequent Contributor
You should be able to see images now. We had a permissions/approval issue. Apologies for the inconvenience
Anonymous
confirmed tx
Anonymous
Hi,
unfortunateley, 2km of cable could mean everything. Usually you have  a loss of 1dB but this highly is dependand of how many patch panels are inbetween, how  the fiber routed, perhaps some bend radius violations .. and so on...
could you check the sfpshow, if you have any light at least and if the light levels are ok?
Also if you have an optical powermeter, pls check the lightlevels..
If nothing helps, you should consider doing an OTDR measurement.
Hope this helps
Uli
Anonymous
Hi
Below is the 'sfpshow' output taken from two respective switches that need to connect
:admin> sfpshow
Port  0: id (sw) Vendor: BROCADE          Serial No: VAF209460000GV5  Speed: 100
,200,400_MB/s
Port  1: id (sw) Vendor: BROCADE          Serial No: VAF209460000GV7  Speed: 100
,200,400_MB/s
Port  2: id (sw) Vendor: BROCADE          Serial No: VAF209460000GTJ  Speed: 100
,200,400_MB/s
Port  3: id (sw) Vendor: BROCADE          Serial No: VAF209460000GUN  Speed: 100
,200,400_MB/s
Port  4: id (sw) Vendor: BROCADE          Serial No: VAF209440000M78  Speed: 100
,200,400_MB/s
Port  5: id (sw) Vendor: BROCADE          Serial No: VAF209460000F8J  Speed: 100
,200,400_MB/s
Port  6: id (sw) Vendor: BROCADE          Serial No: VAF209460000F8G  Speed: 100
,200,400_MB/s
Port  7: id (sw) Vendor: BROCADE          Serial No: VAF209440000JK6  Speed: 100
,200,400_MB/s
Port  8: id (sw) Vendor: BROCADE          Serial No: VAF209440000JK9  Speed: 100
,200,400_MB/s
Port  9: id (sw) Vendor: BROCADE          Serial No: VAF209440000JJ0  Speed: 100
,200,400_MB/s
Port 10: id (sw) Vendor: BROCADE          Serial No: VAF209440000SM6  Speed: 100
,200,400_MB/s
Port 11: id (sw) Vendor: BROCADE          Serial No: VAF209440000JW9  Speed: 100
,200,400_MB/s
Port 12: id (sw) Vendor: BROCADE          Serial No: VAF209460000GPZ  Speed: 100
,200,400_MB/s
Port 13: id (sw) Vendor: BROCADE          Serial No: VAF209440000M70  Speed: 100
,200,400_MB/s
Port 14: id (sw) Vendor: BROCADE          Serial No: VAF209440000JJ2  Speed: 100
,200,400_MB/s
Port 15: id (sw) Vendor: BROCADE          Serial No: VAF209440000JJE  Speed: 100
,200,400_MB/s
Port 16: id (sw) Vendor: BROCADE          Serial No: VAF209460000GVC  Speed: 100
,200,400_MB/s
Port 17: id (sw) Vendor: BROCADE          Serial No: VAF209460000GUT  Speed: 100
,200,400_MB/s
Port 18: id (sw) Vendor: BROCADE          Serial No: VAF209460000GVA  Speed: 100
,200,400_MB/s
Port 19: id (lw) Vendor: BROCADE          Serial No: WCA109314405360  Speed: 100
,200,400_MB/s
Port 20: id (sw) Vendor: BROCADE          Serial No: VAF209440000JJL  Speed: 100
,200,400_MB/s
Port 21: id (sw) Vendor: BROCADE          Serial No: VAF209440000JJF  Speed: 100
,200,400_MB/s
Port 22: id (sw) Vendor: BROCADE          Serial No: VAF209460000ALC  Speed: 100
,200,400_MB/s
Port 23: id (lw) Vendor: BROCADE          Serial No: WCA109314405316  Speed: 100
,200,400_MB/s
:admin>
:admin> sfpshow
Port  0: id (sw) Vendor: BROCADE          Serial No: VAF209460000AVN  Speed: 100
,200,400_MB/s
Port  1: id (sw) Vendor: BROCADE          Serial No: VAF209460000AW5  Speed: 100
,200,400_MB/s
Port  2: id (sw) Vendor: BROCADE          Serial No: VAF209460000AVT  Speed: 100
,200,400_MB/s
Port  3: id (sw) Vendor: BROCADE          Serial No: VAF209460000AW0  Speed: 100
,200,400_MB/s
Port  4: id (sw) Vendor: BROCADE          Serial No: VAF209460000AVK  Speed: 100
,200,400_MB/s
Port  5: id (sw) Vendor: BROCADE          Serial No: VAF209460000AVH  Speed: 100
,200,400_MB/s
Port  6: id (sw) Vendor: BROCADE          Serial No: VAF209460000AVD  Speed: 100
,200,400_MB/s
Port  7: id (sw) Vendor: BROCADE          Serial No: VAF209460000AVR  Speed: 100
,200,400_MB/s
,200,400_MB/s
Port  9: id (sw) Vendor: BROCADE          Serial No: VAF20946000070V  Speed: 100
,200,400_MB/s
Port 10: id (sw) Vendor: BROCADE          Serial No: VAF2094600006ZJ  Speed: 100
,200,400_MB/s
Port 11: id (sw) Vendor: BROCADE          Serial No: VAF209460000710  Speed: 100
,200,400_MB/s
Port 12: id (sw) Vendor: BROCADE          Serial No: VAF20946000071R  Speed: 100
,200,400_MB/s
Port 13: id (sw) Vendor: BROCADE          Serial No: VAF20946000071V  Speed: 100
,200,400_MB/s
Port 14: id (sw) Vendor: BROCADE          Serial No: VAF20946000070T  Speed: 100
,200,400_MB/s
Port 15: id (sw) Vendor: BROCADE          Serial No: VAF20946000070N  Speed: 100
,200,400_MB/s
Port 16: --
Port 17: id (sw) Vendor: BROCADE          Serial No: VAF209430000S30  Speed: 100
,200,400_MB/s
Port 18: id (sw) Vendor: BROCADE          Serial No: VAF209440000FBW  Speed: 100
,200,400_MB/s
Port 19: id (lw) Vendor: BROCADE          Serial No: WCA109314405304  Speed: 100
,200,400_MB/s
Port 20: id (sw) Vendor: BROCADE          Serial No: VAF209450000B7Z  Speed: 100
,200,400_MB/s
Port 21: id (sw) Vendor: BROCADE          Serial No: VAF209430000PNE  Speed: 100
,200,400_MB/s
Port 22: id (sw) Vendor: BROCADE          Serial No: VAF209440000SMM  Speed: 100
,200,400_MB/s
Port 23: id (lw) Vendor: BROCADE          Serial No: WCA109314405342  Speed: 100
,200,400_MB/s
:admin>
Thanks
Anonymous
Hi,
sorry for not beeing precise enough: you would need to execute the sfphsow just for your ISL's like:
 the output should look like:
Identifier: 3 SFP
Connector: 7 LC
Transceiver: 540c404000000000 2,4,8_Gbps M5,M6 sw Short_dist
Encoding: 1 8B10B
Baud Rate: 85 (units 100 megabaud)
Length 9u: 0 (units km)
Length 9u: 0 (units 100 meters)
Length 50u: 5 (units 10 meters)
Length 62.5u:2 (units 10 meters)
Length Cu: 0 (units 1 meter)
Vendor Name: BROCADE
Vendor OUI: 00:05:1e
Vendor PN: 57-1000012-01
Vendor Rev: A
Wavelength: 850 (units nm)
Options: 003a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max: 0
BR Min: 0
Serial No: UAF108050000240
Date Code: 080130
DD Type: 0x68
Enh Options: 0xfa
Status/Ctrl: 0xb0
Alarm flags[0,1] = 0x5, 0x0
Warn Flags[0,1] = 0x5, 0x0
Alarm Warn
low high low high
Temperature: 35 Centigrade -10 90 -5 85
Current: 7.306 mAmps 1.000 17.000 2.000 14.000
Voltage: 3293.4 mVolts 2900.0 3700.0 3000.0 3600.0
RX Power: -3.0 dBm (506.4uW) 10.0 uW 1258.9 uW 15.8 uW 1000.0 uW
TX Power: -3.3 dBm (467.3 uW)125.9 uW 631.0 uW 158.5 uW 562.3 uW
then, you can see if your powerlevels are correct  (RX Power nad TX power values)
Cheers
Uli
Anonymous
1. from the picture I can see the patch cord is of 10 mtr length which will be used only for 50/62.5 micron cable
In this case you need to use LWL SFP with single mode cable 9 microns
SFP is correct, connect with single mode
I guess with your existing LE mode it should work, if you do not intend to use L0
Anonymous
HI All,
Very sorry for replying in late.
Thank you very much for your valuable suggestions and ideas. We were finally able to 'online' the respective switchports. The problem was some impurity thus high noise & signal loss in patch pannels (where "dark fibre" connects).
Regards,
srangama
