Anonymous
Connecting SW3900 and McData 4400
Hi,
I would like to configure a sw3900 and McData 4400 into one fabric.
Is this possible and how to configure both switches into one fabric.
Pls help.
External Moderator
Re: Connecting SW3900 and McData 4400
rob,
--- Is this possible and how to configure both switches into one fabric.
Yes, you can Build a Fabric with Brocade and McDATA.
you must first make sure, both Switch have a compatible OS.
what is the exact release loaded in 3900 and 4400 ?
you must change/set correct the Interopmode and Domain ID, in the Brocade and in the McDATA switch.
Attached is a PDF to Merge a Fabric McDATA to Brocade with Domain ID details.
TechHelp24
Anonymous
Hi Antonio,
About the Brodade switches they are at v5.3.0c but I was not able to gain information about the MCdata 4400's yet.
Is there a way to connect by a serial line to these 4400's? or even set these switches to default so I can connect those via telnet to the default ip address?
Thanks in advanced.
Rob
External Moderator
----Is there a way to connect by a serial line to these 4400's?
attached the Installation and Sevice manuals.
Note, if you have lost the password the switch must be reset, and all License will be lost !
by Default the usename is
"Administrator"
and password is
"password"
TechHelp24
