Anonymous
Changing the ID of Brocade SAN Switches
I want to change the IDs of Brocade SAN switches (Model 5000, Firmware 6.2.2b) in Dual Fabric. Do I need to stop the AIX servers with RDAC multipath driver and DS4700 Storage System before ?
For the SAN switche. I know I must make a disableswitch / enableswitch.
Thank's
Anonymous
Re: Changing the ID of Brocade SAN Switches
Hi anaoui
I'm guessing you want to make a "principal" switch in your fabric ?
This is a non-distruptive process as long as your fabrics are configured correctly , as well as your hosts i.e path managment software.
fabricprincipal -l -f
will make the switch the principal and change all the domain id's for the other switches.
Regards
David
Super Contributor
- anaoui,
--->>> I want to change the IDs of Brocade SAN switches ....
do you want to change the DID = Domain ID ?
if yes,what is the reason for a change ?
when you chnage the DID, you must re-config / re-build the zone/config
Anonymous
Hi,
I want to change the DID (Domain ID) to connect my Switchs to a fabric. Is it necessary to shutdown the AIX servers and DS47000 Storage System connected to the Switch before updating the DID ? I'm in a Dual Fabric configuration.
Thank's
Anonymous
Hi,
We have modified our DID without stop our AIX Servers recently.
We have many Brocade Switches (DCX & 4020 & 4024) and HDS Storage.
For work with AIX, the ODM drivers supply by HDS seems to write the DID in the path of the disks !
Then, when we have changed our DID, we were forced to restart our systems and unconfigure all devices.
Best regards
Super Contributor
--->>>I'm in a Dual Fabric configuration.
In Dual fabric Mode, is not necessary to shutdown the server.
But my question remain,.....
.....what is the reason for Change the DID ?
