Anonymous
Accepted Solution
Can a short wave SFP be used for an ISL for less then 150m ?
Hi
Can a short wave SFP be used for an ISL between two 6510 switches less than 150m apart ?
Regards
Faizel
Occasional Contributor
Re: Can a short wave SFP be used for an ISL for less then 150m ?
Hi Faizell
Sure, as long as you are within the supported range of distance it is not a problem. The supported distance depends on the cable quality and the link speed. With a OM3 cables you can support up to 150 meters with a speed of 8G.
Regards
Rico
Anonymous
Thanks Rico
