Anonymous
Accepted Solution
Brocade SW300 connect IBM Flex system FC3171 SAN switch issue
Hi All,
I have a Brocade 300 san switch have to connect to IBM Flex system FC3171 san switch . After connect fiber cable, in brocade end the port show [G port] status. In IBM end the port show [offline]. I connect storage to IBM san switch directly, it ok . so i think all san switch is work fine.
In brocade san swithc i get some warning like: [port 1: ILS ELP bad size 144, wanted 164.]
Brocade switch license info :
admin> licenseshow
GZPYg4axxxxxxxxxxxxxxrN3mtBJfQE:
Enhanced Group Management license
mBfEND7YxxxxxxxxxxxxxxHCA3BXgHWBAXMD:
8 Gig FC license
WHWQmT7xxxxxxxxxxxxxAXWmB3DWJB7NGH:
First Ports on Demand license - additional 8 port upgrade license
Is it license issue or brocade 300 did not support to connect IBM san switch or some issue esle?
Pls help me !!
External Moderator
Re: Brocade SW300 connect IBM Flex system FC3171 SAN switch issue
dean,
the FC3171 is Qlogic Based Switch/ Pass-thru Blade.
I'm not familiarly with this Blade, but I think in order to ISL and/or build a fabric with Brocade, the FC3171 must be set in NPIV Mode and not in Full Fabric-Mode.
if you can point me to some DOC, user guide,  command line guide, etc..  i'll try to help you to config out.
TechHelp24
External Moderator
[ Edited ]
Dean,
Finally I found IBM Redbooks sg247984-04.
I assume you want to connect the Storage to the Brocade 300, and ISL the IBM Flex FC3171 to Brocade 300.
in such case, the FC3171 must be set as Pass-Thru
TechHelp24
Anonymous
Dear
External Moderator
Hi Dean,
happy to hear that work now.
since problem is solved I marked this topic as a Solutions  Your are welcome if you have another inquier
TechHelp24
