New Contributor
Brocade 300 Serial Connection
Hi there,
I try to connect to a brocade 300 via COM Port , but it does not work at all.
I need this because of pw recovery of "root"
Serial Settings are 9600,8,N,1 , flow control -> none as mentioned in the manuals.
For terminal client i tried with putty and hyper terminal i also tried both local serial port with an older laptop and usb to serial converter.
I also tried rebooting the switch , cold boot and so on
But i do net get any connection ....!!
Does anyone know how what the problem could be?? this is really wierd...
Thanks in advance
daniel
Valued Contributor
Re: Brocade 300 Serial Connection
make sure you are using brocade branded rs232 cable that was provided with the switch
New Contributor
Hi,
Yes sure , im using the standard brocade rs232 cable...
greets
External Moderator
Daniel,
-->> Yes sure , im using the standard brocade rs232 cable...
you need the cable Kit with Part Number 50-0000176-01 and Connector 50-0000177-01
should you have the right cable Kit, most probable COM configuration is not set properly.
TechHelp24
New Contributor
Hi and good Morning,
Thank you this could be the reason ,
The Cable provided with the Switch is 50-0000083-01 and the Connector is 50-0000890-01 !
I will try to get the right Cable Kit...
greets
New Contributor
Hi,
I bought a CISCO Serial Cable and it works Fine!
Thank you
Valued Contributor
i've just had a look at my good old cable kit that i'm using for ~15 years and the cable p/n is 72-0876-01 ;)
