Anonymous
Attach edge to AP7500 as EX_Port ?
Hello,
When attach edge switch to AP7500 with ex_port, should edge switch have fabric license ?
Any paper indicate such information. Thank you.
edge (e-port) <-> (ex_port) ap7500
Best regards,
Anonymous
Re: Attach edge to AP7500 as EX_Port ?
e - ex port is called IFL(Inter fabric link) . It is just like an ISL. Fabric license is required.
Super Contributor
matthew,
--->>>....should edge switch have fabric license ?
A Fabric License is by Default Installed, excepted some Old Switch Model.
What is the switch Type/Modell you want to connect to AP7500 ?
Whit command "licenseshow" are you able to verify the Installed License,
