Frequent Contributor
8 trunks with 2 links each or 4 trunks with 4 links each
as the topic says
what would you go for
connect your directors with 8 trunks where every trunk consists of 2 links or go with 4 trunks consisting of 4 links each?
do more trunks handle traffic better
q/d
External Moderator
Re: 8 trunks with 2 links each or 4 trunks with 4 links each
I would create a Single Trunk-Group.
--->>>do more trunks handle traffic better
from my point of view, the answer is NO, as follow reason.
If you create more trunk-group betwen the same switch/director, you have more ISL - in a trunk - and suchs work like DPS/EBR = Dynamic Path Selection/Exchange Based Routing:
Exchange-based routing (EBR) uses all available (equal-cost) routes between source port and destination port,
with individual exchanges assigned a single route. Although it represents a more efficient use of available
bandwidth, it is potentially more disruptive because of changes introduced into the fabric without lossless
Dynamic Path Selection (DPS).
TechHelp24
Regular Contributor
Hi All,
if you have more trunks between two Directors and you terminate them on different Blades,
then you have a higher availability in a case of Blade outage.
But then think about the statement of Antonio.
Regards Ralf
Kind Regards
Ralf
