Anonymous
3016 Upgrade problems fabosShowInit failed: 2?
I have a Brocade Blade Swicth slimwork 3016 firts its has firmware level 5.0.5c then was upgrade to 5.1.0c and its ok, but when i upgrade to
5.3.0d the firmware was loaded but when reboot i cant execute any command or see on the web
login as: USERID
USERID@10.0.3.114's password:
brocadessm:USERID> version
brocadessm:USERID> firmwaredownloadstatus
brocadessm:USERID>
Anonymous
Re: 3016 Upgrade problems fabosShowInit failed: 2?
Hi jmanzo
I assuming this 3016 is in a Blade Chassis.
Try this ( if you have an IBM blade chassis)
1. Go to the I/O mudule tasks and restart the switch module with "full diagnostics"
If that fails then try the following.
2.
Login into your blade chassis management module , and go to I/O Module tasks.
Then find your switch module.
Go to the Advance configuration.
Then select the "Restore to Factory Defaults"
Good luck
David
