External Moderator
Re: 24000 Director - Flash Monitor
Rob,Do you have run ( by admin ) the command "supportshow" to see if any dump available ?
TechHelp24
Anonymous
I was able to find some dump files in the /var directory on both file systems & delete them - I'm now at 68% in-use & now the switch's Flash monitor states it is in a healthy state. Thanks for all your help!Rob
External Moderator
Rob,Are the actually 68% in the /dev/root or in the /dev/hda2/ partition ?
TechHelp24
Anonymous
Here is the following from DF../dev/hda2 120128 76652 43476 64% /mnt
