Hi all,
i'm trying to edit allocationcurve from staff in a project using rest api with a simple process, however the expected result in the MUX is not correct
i'm trying to send 288000 s ( 10 manday), however i get 261 in the MUX
Here is a part of the script:
<core:set var="REST_URL">/projects/6064011/teams/6659379</core:set>
<core:set escapeText="false" var="JSON_DATA">
"_internalId": 6659379,
"allocationCurve": {
"isFiscal": false,
"curveType": "value",
"dataType": "numeric",
"_type": "tsv",
"segmentList": {
"defaultValue": 0,
"segments": [
"start": "2025-01-01T00:00:00",
"finish":"2025-12-31T00:00:00",
"value": 288000
</core:set>
do you have any idea to resolve this problem ?
thank you
