VMware vSphere
  • 1.  Using StandAlone Converter with SSH Tunnel and keys, no passwords
    Posted Apr 21, 2015 03:59 PM
    I'm trying to convert a remote centos 6.5 box that I access via putty with ssh keys,  no password.    I created the local ssh tunnels but the converter requires a username and password.    The linux box is setup for ssh keys only,  no passwords.   Is there a work around for this?
  • 2.  RE: Using StandAlone Converter with SSH Tunnel and keys, no passwords
    Posted Apr 21, 2015 04:50 PM
    Hello
    The workaround is this - edit your sshd_config file and set:
    PasswordAuthentication yes
    PermitRootLogin yes
    More seriously - Converter does not support SSH key login, you have to use password.
    HTH
    Plamen
  • 3.  RE: Using StandAlone Converter with SSH Tunnel and keys, no passwords
    Posted Apr 24, 2015 02:06 PM
    Wow!   That's pretty short sighted.   Most Cloud platforms require key access.
