Hello,
I am trying to figure out how to get two VMs to talk to each other using a vDS. Specifically when both VMs are in different hosts.
Both hosts vsphere1 and vsphere2 are connected to the same physical switch. One of the VMs "ubuntu(firewall/router)" is on vsphere1 and the second VM "centos" is on vsphere2.
I will not be using any vlans at this moment because I need to figure this out first.
My configuration is as follows:
vCenter 5.1
vSphere 5.1
vDS name: Homenet.vDS0
Uplink Portgroup: Homenet.pg0-DVUplinks
vmnic5 vsphere1
vmnic5 vsphere2
VM:ubuntu(vmnic0)
VM: ubuntu (two interfaces)
vmnic0:192.168.2.20 (physical network)
vmnic1:10.0.1.20 (Security.pg1)
Note: vmnic1 would be the gateway for the VM in the "Security.vDS1" vDS
vDS name: Security.vDS1
Uplink Portgroup: Security.pg1-DVUplinks
vmnic5 vsphere1
vmnic5 vsphere2
VM: ubuntu (vmnic1)
VM:centos(vmnic0)
VM: centos (one interface)
vmnic0:10.0.1.30 (Security.pg1)
Each host (vsphere1 and vsphere2) has one interface conneced the vDS "Homenet.pg0-DVUplinks" and "Security.pg1-DVUplinks"
I want to be able to have the"centos" VM use the "ubuntu" VM as a router/firewall to limit what goes out via the uplinks. I dont want the "centos" vm to have connectivity to the physical network unless it goes through the "ubuntu" VM. Is there a way that I can tell the portgroup that holds the "centos" VM to only go through the "ubuntu" VM?
The vSphere Networking guide mentions the following so I assume that it can be accomplished.
To protect your most sensitive virtual machines, deploy firewalls in virtual machines that route between
virtual networks with uplinks to physical networks and pure virtual networks with no uplinks.
thanks in advance!
