vCloud
  • 1.  convert edge gateway to advanced gateway
    Posted May 29, 2020 01:36 PM
    Was trying to get a PowerShell script to convert edge gateway to advanced gateway on vCloud Director 9.1, we have some 100's of edges and would like to automate this process as we are planning an upgrade of VCD
  • 2.  RE: convert edge gateway to advanced gateway
    Posted Jul 15, 2020 10:44 PM
    Here is a simple rest call powershell command I wrote because I had about 4000 or more.
    This is not complete but hopefully you get the gist (I didn't want to have to rip all my code up and sanitize it for web).
    $vcloud = connect-ciserver
    $sessionid = $vcloud.sessionid
            $AllProtocols = [System.Net.SecurityProtocolType]'Ssl3,Tls,Tls11,Tls12'
            [System.Net.ServicePointManager]::SecurityProtocol = $AllProtocols
    $egws = get-edgegateway
    foreach($edgegateway in $egws){
            $edgeid = $edgegateway.id.replace("urn:vcloud:gateway:","")
            $upgradeURI = ("https://$vcloud/api/admin/edgeGateway/$edgeid/action/convertToAdvancedGateway")
            $headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
            $Headers.Add('x-vcloud-authorization', $sessionkey)
            $Headers.Add('accept','application/*+xml;version=31.0')
            $Headers.Add('Content-Type','application/xml')
            $wr = (Invoke-WebRequest -uri $upgradeURI -Method Post -Headers $headers -UseBasicParsing).content
            #check the status of the changes
            [xml]$wrxml = $wr
            $wrtaskhref= $wrxml.Task.href
            Write-Verbose  "wrtaskhref: $wrtaskhref"
            try{
                while($ts -ne 'success')
                [xml]$taskstatus = (Invoke-WebRequest -uri $wrtaskhref -Method get -Headers $headers).content
                $ts = $taskstatus.Task.Status
                Write-Verbose "ts: $ts"
                start-sleep -Seconds 3}
                catch{}
