This is an old thread, but I found it on search for issues with ESXi 4.0u1
and the CERC 1.5/6ch RAID controller. Figured I'd post
an answer in case others are having the same issues and using the same
search. I had a lot of SCSI errors in the logs pointing to an issue
with the aacraid driver. This is commonly accepted as a non-working
controller for ESXi 4.0 and I just left it out of the server and used the
onboard SATA controller.
With the introduction of ESXi 4.1, it WORKS!!! On a whim, I
re-installed the CERC 1.5/6ch card (Adaptec 2610SA) and loaded a clean
install of ESXi 4.1 on the SATA drive connected to the onboard SATA
controller. Rebooted and it recognized the CERC 1.5/6ch controller and
the RAID-5 array I had made with 5 drives using the BIOS utility. I was
able to format a VMFS datastore and used the entire array for iSCSI
storage with OpenFiler (this was where it always hung and crashed on the ESXi 4.0). Some benchmark testing shows the CERC
controller being slightly slower than the single SATA drive connected
to the onboard controller. However, after turning on write-caching, it
was about 10-15% faster.
Not super performance by any means, but I'm glad I was able to finally
use this card for creating a 2-TB volume for backing my VMs..
