VMware vSphere
  • 1.  SSH session exit kills running job - nohup same result - help
    Posted Jan 21, 2021 03:25 PM
    Good Morning,
    I have a script on ESXi that I need to be able to ssh into, execute the script, disown the process and exit ssh session, while keeping the process running?  I have tried executing it the following ways:
    nohup /etc/run_command
    nohup /etc/run_comand &
    I have also run across trying this example: (Website - Sudoall.com)
    exec </dev/null >/dev/null 2>/dev/null
    but I must not be using it right, because I get the same results.
    Is there a way to disown the process, exit the ssh session without killing the running process on ESXi?
  • 2.  RE: SSH session exit kills running job - nohup same result - help
    Posted Jan 21, 2021 06:23 PM
    After a lot of google research, I stumbled across this Website. ESXi does not have screen, tmux, or disown. An nohup was not working...I gave setsid a shot, and it worked.
    setsid /etc/run_command &
  • 3.  RE: SSH session exit kills running job - nohup same result - help
    Broadcom Employee
    Posted Jan 22, 2021 09:38 AM
    to be honest, you are not really supposed to run scripts directly on ESXi to begin with...
