Good day
I'm trying to set up vCenter correctly but I can't
I ran into the following problem
I still get an error All required hosts are in maintenance mode
If the host x.x.230.32 I remove there the error will disappear
But if I add it an error will reappear. I have everything configured in the same way as on the first server.
The message that appears
Check if all hosts in the cluster which have not been configured for hyperconverged cluster are in maintenance mode. If the host running the current vCenter is in the cluster then it will be excluded from this check.
The problem is that there are no disks on the servers.
I connect all storage via ISCSI. I have neither a vSAN nor any other SAN.
this guest don't even know to switch to maintenance mode.
Can you please advise me where I am making a mistake?
I am sending printscrean in the attachment
well thank you
Michal
